jholder Posted July 21, 2006 Share Posted July 21, 2006 I've seen that the 2005 lgt do not have adjustable camber from the factory. I've seen several posts saying that you can purchase camber bolts to adjust it, and several saying that bolts wouldn't work. Definitively, wWhich is it? Also, if there are rear camber bolts available, could someone provide a link? Thanks, --james Link to comment Share on other sites More sharing options...
rc0032 Posted July 21, 2006 Share Posted July 21, 2006 No camber bolts wont work. But you can get these for the rear. http://legacygt.com/forums/suspension-brakes/39089-adjustable-rear-control-arm.html Link to comment Share on other sites More sharing options...
Th3Franz Posted July 22, 2006 Share Posted July 22, 2006 What alignment do people often run in the rear? I installed my JDM Bilsteins and pinks last night and I need a new alignment bad. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Xenonk Posted July 22, 2006 Share Posted July 22, 2006 I set the toe to zero in the rear.. if you want your car to drift, set the rear to some toe-out (1/8") if you want stability and a better turn in, toe it in (1/16") Keefe Link to comment Share on other sites More sharing options...
