Two-Five Sti-L Posted July 18, 2006 Share Posted July 18, 2006 Hi all, I'm curious to see what exhaust mods has everyone been able to get away with during inspections. I plan to retain at least 1 (mid-pipe oem) cat in order to have a passing chance. Is it sufficient or do I need to retain more oem equipment? I'm trying to plan ahead in terms of mods and would hate to swap back stock parts annually just to pass emissions. For those w/exhaust mods pls list what you have for everyone's comparison and benefit, thanks!! Link to comment Share on other sites More sharing options...
jim1969 Posted July 18, 2006 Share Posted July 18, 2006 For emissions it won't matter. they use OBDII protocol. No sniffer. There is a visual inspection however. I'd leave one in the midpipe (stock or HFC) since that's the most visible one unless you are comfortable with the inspector. Link to comment Share on other sites More sharing options...
Two-Five Sti-L Posted July 19, 2006 Author Share Posted July 19, 2006 For emissions it won't matter. they use OBDII protocol. No sniffer. There is a visual inspection however. I'd leave one in the midpipe (stock or HFC) since that's the most visible one unless you are comfortable with the inspector. I'm aware that all 96+ cars aren't required to go on the dyno anymore, but rather the obdII port. So are you saying that as long as we can disable/bypass the sensors for the missing cat(s) we would pass w/o problems? Link to comment Share on other sites More sharing options...
Edvig Posted July 19, 2006 Share Posted July 19, 2006 You will pass the OBDII scan as long as you have no CELs showing and your ECU is able pass all it's readiness tests. The visual test is a whole other thing. Link to comment Share on other sites More sharing options...
Mui01 Posted July 19, 2006 Share Posted July 19, 2006 Its good to know:icon_bigg Link to comment Share on other sites More sharing options...
Edvig Posted July 20, 2006 Share Posted July 20, 2006 just an fyi...some guys have had trouble passing. NASIOC - NY inspection... guess people were wrong:+( Link to comment Share on other sites More sharing options...
SubLo Posted July 20, 2006 Share Posted July 20, 2006 For emissions it won't matter. they use OBDII protocol. No sniffer. There is a visual inspection however. I'd leave one in the midpipe (stock or HFC) since that's the most visible one unless you are comfortable with the inspector. Sorry. But this is just not true (entirely). You're right about the visual inspection. It depends on the technician. Most techies in my 'hood don't care or are easily bought on the visual. The first two years - yes... you will simply have the OBDII port scan and the visual. However, here's where I have issue with your comment. After the first two years, you must pass the smog/sniffer test and have minimal NYS levels of CO and NO just like every other vehicle on the road. I'm really curious to know if anyone in NYS has hit the 2 year mark and passed with a catless UP or more removed. The easy way around all of this is to retain your stock setup and swap it in/out before/after inspection respectively. ________________________________________________ [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1980"]'05 BSM OBXT Row-your-own, W.I.P. :rolleyes:[/URL] [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1242"]'06 Shrek B # 64 - The car the wife loved to hate :( Sold...[/URL] Link to comment Share on other sites More sharing options...
JBLU24 Posted July 20, 2006 Share Posted July 20, 2006 NYS has done away with the sniffer since Jan of 2005.... we're strictly OBD and visual inspection only the 1st 2 years are only visual/"safety" and even back before 2005 if he had to do a sniffer it would be bypassed because they only have 2wd dynos- AWD cars skipped it since my car has no CEL I have passed an OBD inspection and event though I'm catless there was no visual for reasons stated above by sublo..... edit: this applies to vehicles 1996 and up before 1996 they dont do the obd test they still do the dyno/sniffer test.... Link to comment Share on other sites More sharing options...
Edvig Posted July 20, 2006 Share Posted July 20, 2006 I'm really curious to know if anyone in NYS has hit the 2 year mark and passed with a catless UP or more removed. The easy way around all of this is to retain your stock setup and swap it in/out before/after inspection respectively. There are tons of WRX guys that have past the 2 year mark on their modded cars. Link to comment Share on other sites More sharing options...
eL GaTo Posted July 25, 2006 Share Posted July 25, 2006 There are tons of WRX guys that have past the 2 year mark on their modded cars. Our '02 WRX with no cats (Daddysccp fake 3rd cat delete) passed with just the OBDII check. "Remember..."MODDING is a HOBBY:icon_bigg, not a BAAAD HABIT";) . Link to comment Share on other sites More sharing options...
