team23jordan Posted July 17, 2006 Share Posted July 17, 2006 I have 18" Enkei Rp02 they are 18x7.5 et48mm would they clear STi's huge front calipers?? Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
team23jordan Posted July 17, 2006 Author Share Posted July 17, 2006 I heard that if the wheels r 7.5" wide, the offset has to be 50+mm.. if thats true, i think i'm gonna need get some spacers if i get brembos Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
Th3Franz Posted July 17, 2006 Share Posted July 17, 2006 if you are getting brembos.. get an 8" wide rim and run a tire to make better use of Brembos. But if you insist on your current rim, I don't have a definite answer for ya. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
team23jordan Posted July 18, 2006 Author Share Posted July 18, 2006 aight they are on sale.. http://legacygt.com/forums/member-classifieds/38944-fs-sti-front-brembo.html#post678799 Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
SC GT Posted July 18, 2006 Share Posted July 18, 2006 I have 18" Enkei Rp02 they are 18x7.5 et48mm would they clear STi's huge front calipers?? I heard that if the wheels r 7.5" wide, the offset has to be 50+mm.. if thats true, i think i'm gonna need get some spacers if i get brembos These two statements taken together don't make sense. If a 50 mm offset is good for Brembos, a 48 mm offset would be better. Spacers reduce offset and make your wheels stick out further from the hub. So, if you were to use 3 mm spacers, your effective offset would be 45 mm. Having said that, offset is only half the equation. The other half is spoke design. That is why Rota wheels (all of which are 48 mm offset) like the Tarmac 2 and SDRs where the spokes are at the outer-most portion of the rims, fit Brembos, and rims like the original Tarmac and the Actions won't fit Brembos. Having said all that, the RP-02s look similar to the SDRs and Tarmac 2s where the spoke are close to the face. I couldn't say for sure, but if I had to guess whether or not they'd clear Brembos, I'd guess that they would. And they would almost certainly clear the Brembos with 3 mm spacers, if you could get spacers that small. If I were you, I'd try to find someone with an '04 STi pay him $20 to let you see if your rims would clear his front Brembos. Good luck. p.s. You should have bought those Crimson K6s I was selling. Link to comment Share on other sites More sharing options...
GTurabus Posted July 18, 2006 Share Posted July 18, 2006 I searched for the same info in the big NASIOC fitment FAQ. The wheel is not listed in the front, as the list was not updated with every post. After having gone through nearly every page, there is a post (around page 20 or so) that states the 18" RP02 does clear. I have both the Brembo's and the same wheels, but have not installed either because of my house renovation. I can let you know definitively in about a month. Link to comment Share on other sites More sharing options...
Xenonk Posted July 18, 2006 Share Posted July 18, 2006 but does that width and offset clear?? Keefe Link to comment Share on other sites More sharing options...
team23jordan Posted July 19, 2006 Author Share Posted July 19, 2006 p.s. You should have bought those Crimson K6s I was selling. i know. i regret it now I searched for the same info in the big NASIOC fitment FAQ. The wheel is not listed in the front, as the list was not updated with every post. After having gone through nearly every page, there is a post (around page 20 or so) that states the 18" RP02 does clear. I have both the Brembo's and the same wheels, but have not installed either because of my house renovation. I can let you know definitively in about a month. can you let me know asap? cuz i'm gonna order speed star D2R or D5R from tirerack as soon as i get my paycheck..but if rp02 works than i dont have to buy new wheels thanks man!! Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
team23jordan Posted July 20, 2006 Author Share Posted July 20, 2006 just test fitted on one of local STi owner from nasioc it does NOT clear brembos it's soo close to clearin em tho... it'll def work with a set of spacers and longer bolts Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
