camber Posted July 9, 2006 Share Posted July 9, 2006 Meh... Decided i would post this. My front strut tower bar, rear swaybar and front swaybar are Whiteline and I've been harrassing them to confirm some part number for endlinks and swaybar lock kits. They sent me this list. The following Whiteline parts are available for: Subaru, Legacy, Legacy (Liberty) BE,BH 99-02 incl B4 GT All prices are in AUS$ excluding delivery. Australian customers need to add 10% GST. Part Number: KCA319A Description: Front Anti-lift/caster kit - lwr c/arm Notes: adds +0.5 deg caster plus anti-lift adds +0.5 deg caster plus anti-lift Qty in Kit: 2 Vehicle Kit: Price: $223.64+ ------------------------------------------------------------------ Part Number: KCA319M Description: Front Anti-lift/caster kit RACE Notes: adds +0.5 deg caster plus anti-lift - hard/black adds +0.5 deg caster plus anti-lift - hard/black Qty in Kit: 2 Vehicle Kit: Price: $240.36+ ------------------------------------------------------------------ Part Number: KCA361 Description: Front Anti-lift/caster kit COMFORT Notes: adds +0.5 deg caster plus anti-lift - soft adds +0.5 deg caster plus anti-lift - soft Qty in Kit: 2 Vehicle Kit: Price: $224.09+ ------------------------------------------------------------------ Part Number: KCA375 Description: Front Caster adj kit - lwr c/arm Notes: +/- 0.5 deg Qty in Kit: 2 Vehicle Kit: Price: $140.00+ ------------------------------------------------------------------ Part Number: KCA375M Description: Front Control arm-caster adj.-Msport BLACK 90D RACE Notes: Adds +0.5 static caster Qty in Kit: Vehicle Kit: Price: $159.09+ ------------------------------------------------------------------ Part Number: KCA414 Description: Front Camber adj bolt kit-14mm RACE Notes: replaces lower bolt < -3.0 deg RACE only +/- 1.5 deg Qty in Kit: 2 Vehicle Kit: Price: $76.82+ ------------------------------------------------------------------ Part Number: KLC20A Description: Front Sway bar link conv kit - steel Notes: replaces OE plastic link Qty in Kit: 2 Vehicle Kit: Price: $78.64+ ------------------------------------------------------------------ Part Number: KLC30 Description: Front Sway bar link conv kit - extra h/d alloy Notes: replaces OE plastic link replaces OE plastic link Qty in Kit: 2 Vehicle Kit: Price: $139.55+ ------------------------------------------------------------------ Part Number: KLC32 Description: Front Sway bar link conv - alloy Notes: replaces OE ball joint link Qty in Kit: 2 Vehicle Kit: Price: $139.91+ ------------------------------------------------------------------ Part Number: KSB550 Description: Front Brace-strut tower alloy adj Notes: mid mount mid mount Qty in Kit: 1 Vehicle Kit: Price: $186.36+ ------------------------------------------------------------------ Part Number: W0405-18 Description: Front Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0405-19 Description: Front Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0405-20 Description: Front Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0405-21 Description: Front Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0405-22 Description: Front Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0405-23 Description: Front Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0405-24 Description: Front Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: 73170 Description: Front Spring-coil lowering kit Control Notes: Check ID of top of original coil. If top and bottom ID = 146mm use 70198 Qty in Kit: 2 Vehicle Kit: Price: $158.18+ ------------------------------------------------------------------ Part Number: BSF14 Description: Front Swaybar-heavy duty Notes: High performance mounts and link kits available. Front steel-KLC20A alloy-KLC30, rear steel-KLC19 alloy-KLC26. Excludes STi front. Rear extra heavy duty swaybar mounts available KBR20-(bar size). 20/22/24mm available eg KBR20-22 for 22mm bar. Qty in Kit: 1 Vehicle Kit: Price: $213.64+ ------------------------------------------------------------------ Part Number: BSF14X Description: Front Swaybar-X heavy duty Notes: High performance mounts and link kits available. Front steel-KLC20A alloy-KLC30, rear steel-KLC19 alloy-KLC26. Excludes STi front. Rear extra heavy duty swaybar mounts available KBR20-(bar size). 20/22/24mm available eg KBR20-22 for 22mm bar. Qty in Kit: 1 Vehicle Kit: Price: $213.64+ ------------------------------------------------------------------ Part Number: BSF15 Description: Front Swaybar-heavy duty Notes: Qty in Kit: 1 Vehicle Kit: Price: $213.64+ ------------------------------------------------------------------ Part Number: BSF15Z Description: Front Swaybar-h/duty Blade adjustable Notes: Qty in Kit: 1 Vehicle Kit: Price: $213.64+ ------------------------------------------------------------------ Part Number: KLC38 Description: Front Swaybar link kit-spherical rod end Notes: adj extra h/duty replaces OE plastic type Qty in Kit: 2 Vehicle Kit: Price: $139.55+ ------------------------------------------------------------------ Part Number: KLC39 Description: Front Swaybar link kit-spherical rod end Notes: adj extra h/duty replaces OE ball-joint type Qty in Kit: 2 Vehicle Kit: Price: $139.55+ ------------------------------------------------------------------ Part Number: W0406-15 Description: Rear Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0406-17 Description: Rear Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0406-18 Description: Rear Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0406-19 Description: Rear Bush kit-swaybar to chassis mount Notes: 19 mm Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0406-20 Description: Rear Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0406-22 Description: Rear Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: W0406-24 Description: Rear Swaybar to chassis bush kit Notes: Qty in Kit: 2 Vehicle Kit: Price: $19.09+ ------------------------------------------------------------------ Part Number: 73171 Description: Rear Spring-coil lowering kit Control Notes: Qty in Kit: 2 Vehicle Kit: Price: $158.18+ ------------------------------------------------------------------ Part Number: 73172 Description: Rear Spring-coil lowering kit Control Notes: Qty in Kit: 2 Vehicle Kit: Price: $158.18+ ------------------------------------------------------------------ Part Number: BSR12 Description: Rear Swaybar-heavy duty Notes: Qty in Kit: 1 Vehicle Kit: Price: $213.64+ ------------------------------------------------------------------ Part Number: BSR12X Description: Rear Swaybar-X heavy duty Notes: Qty in Kit: 1 Vehicle Kit: Price: $213.64+ ------------------------------------------------------------------ Part Number: BSR12XZ Description: Rear Swaybar-X h/duty Blade adjustable Notes: Qty in Kit: 1 Vehicle Kit: Price: $213.64+ ------------------------------------------------------------------ Part Number: KLC044 Description: Rear Swaybar link kit-spherical rod end Notes: adj extra h/duty Qty in Kit: 2 Vehicle Kit: Price: $166.64+ ------------------------------------------------------------------ Link to comment Share on other sites More sharing options...
DLC Posted July 11, 2006 Share Posted July 11, 2006 Awesome info, I might post this elsewhere. Link to comment Share on other sites More sharing options...
Flanders Posted July 11, 2006 Share Posted July 11, 2006 They used to have a rear Strut Tower bar for BE/BH. I was hoping to buy one. Here is my current Whitline shopping list: Front Sway BSF14X Rear Sway Bracket KBR20-24 ALK KCA361 Endlinks F&R KLC30 & KLC26 Front Strut Tower KSB550 I already have the rear adjustable bar. Link to comment Share on other sites More sharing options...
camber Posted July 11, 2006 Author Share Posted July 11, 2006 You'll probably have to go with the Cusco rear tower brace for the BH Flanders. Some one was selling one on Nasioc about a month ago but I believe it has been sold. Rear Sway Bracket KBR20-24 will not fit the BE/BH. We have a new heavier RSB mount and Whiteline doesn't make any Reinforcement. Whiteline says the RSB mount is sufficient for upgraded RSB but I have noticed that the new Legacy's have the same type of mount. Cobb has made a reinforcement for the new Legacy's that looks like it will work on our cars. I think the mount comes with the newer Cobb RSBs. Link to comment Share on other sites More sharing options...
DLC Posted July 11, 2006 Share Posted July 11, 2006 Yeah, it's been sold...to me! Link to comment Share on other sites More sharing options...
Flanders Posted July 11, 2006 Share Posted July 11, 2006 "We have a new heavier RSB mount" Who is "we"? Link to comment Share on other sites More sharing options...
camber Posted July 12, 2006 Author Share Posted July 12, 2006 "we" means people that own a BE/BH Legacy. The RSB mount of the BE/BH are different to the Impreza and earlier Legacy's. Link to comment Share on other sites More sharing options...
Flanders Posted July 12, 2006 Share Posted July 12, 2006 Ahh, got it. I will take it off my list. I really want to find the rear strut tower bar with quick release. Link to comment Share on other sites More sharing options...
