BOXRPWR Posted July 9, 2006 Share Posted July 9, 2006 noticed the toggle switch has felt clunky for the last few months. today, it just stopped working altogether. frustrating but I guess it can be replaced fairly easily. long past my warranty period so gotta find out what the part costs from the dealership on Monday. anybody else having a clunky switch? Link to comment Share on other sites More sharing options...
BOXRPWR Posted July 10, 2006 Author Share Posted July 10, 2006 damned thing's working again now.......weird. Link to comment Share on other sites More sharing options...
underpowerd Posted July 10, 2006 Share Posted July 10, 2006 yeh, it got stuck in the 'auto' position. happened to me last week; was out of the car for like 10 minutes, returned to find window uncooperative on startup (must have been stuck), switch felt a little inclined to stick in 'auto' when flicked back and forth. after 30 seconds or so leaving it alone (not stuck position), power returned. no probs since, but now more careful to make sure it's not stuck when/after i use it. Link to comment Share on other sites More sharing options...
05 GT LTD Owner Posted July 10, 2006 Share Posted July 10, 2006 anybody else having a clunky switch? Yes. Got a picture of what it looks like when removed? On my list of things to do. Link to comment Share on other sites More sharing options...
S4 Posted July 10, 2006 Share Posted July 10, 2006 My driver switch for the driver side rear window just went. Most little things that break I can live with, but damn not being able to control the windows! Link to comment Share on other sites More sharing options...
pflo Posted July 11, 2006 Share Posted July 11, 2006 mine has a similar problem: seems sticky and just about ready to die will ask for warranty replacement next service Link to comment Share on other sites More sharing options...
melayout Posted July 11, 2006 Share Posted July 11, 2006 Same here. I keed I keeed Link to comment Share on other sites More sharing options...
Guest Posted July 11, 2006 Share Posted July 11, 2006 It's crappy Nissan made switch. It eventually always dies. In my 98 Alitma it started dying after 8 years. Just replaced it. Link to comment Share on other sites More sharing options...
bradb555 Posted July 11, 2006 Share Posted July 11, 2006 I have one of those magical switches on my tahoe also! I don't need another one! Link to comment Share on other sites More sharing options...
05 GT LTD Owner Posted July 11, 2006 Share Posted July 11, 2006 So I removed the door panel removed & completely disassembled the switch (really didn't need to) Here’s what I found: The drivers window switch is actuated by a "slide" type switch, while all the other windows, locks, an such are "rocker" type "My" problem was a "plastic pin". Being it's a slide switch, it uses a spring and plastic pin to re-center itself in the pocket. When I opened it up, I thought the bottom of the pin looked a little too sharp. (Pointed) I made it nice and round with a small file. Snapped it back in.... NO GO, same notchy feeling as before. So then I "flattened out" the very tip, leaving slightly rounded sides. BINGO! Works as good as, if not better than new. I have a feeling I'll be doing this job more than once. Sorry no pictures. Notes: There are 5 screws to remove the switch from the back of the door panel. (Looks like 4, but there IS 5) For this particular fix, there is no need to completely disassemble the switch. Remove it from the plastic garnish, and you can pry the driver switch "rocker" off from the top. Be careful not to break the rocker/lever. Don't loose the pin or spring on top of it. The rest is obvious. Good luck! Link to comment Share on other sites More sharing options...
c-lo Posted July 11, 2006 Share Posted July 11, 2006 mines clunky too 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
c-lo Posted July 27, 2007 Share Posted July 27, 2007 mine stopped working today for a few minutes. definitely sticky. another thing that needs to be fixed. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
LEGGTLTD Posted July 27, 2007 Share Posted July 27, 2007 Mine sticks several times a week.. Megan header,Perrin TMIC, TD06-20G,AEM CAI, Lachute DP, Avo BOV, BC Coilovers, Magnaflow catback, Hawk HPS pads, Stoptech lines, Snow WI Link to comment Share on other sites More sharing options...
Legacy05 Posted July 27, 2007 Share Posted July 27, 2007 Same thing has happened to me .... Link to comment Share on other sites More sharing options...
LongHiway Posted July 27, 2007 Share Posted July 27, 2007 Ditto me but, then it started working just fine. Link to comment Share on other sites More sharing options...
pillboy Posted July 27, 2007 Share Posted July 27, 2007 I hate driving with my windows down and I don't use drive thru's so that I don't curb a wheel. Power windows don't break on my cars. It is still ugly. Link to comment Share on other sites More sharing options...
SpeedNeeder Posted July 28, 2007 Share Posted July 28, 2007 My switch wouldn't work a couple weeks back, made a funny plastic noise when I pushed it and then wouldn't work. I tried a few times more to no avail, then I locked and unlocked the windows several times (button by the driver window button) and hear another funny plastci noise, then the driver window buttom worked, has been working since. I will bring this up at my next trip to the dealer. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
franklin Posted July 28, 2007 Share Posted July 28, 2007 mine stopped working today for a few minutes. definitely sticky. another thing that needs to be fixed. Weird. Mine did the same today... stuck for a moment and then worked. Sounds like a common fail point. Link to comment Share on other sites More sharing options...
c-lo Posted July 28, 2007 Share Posted July 28, 2007 ^^thought I'd let it go as long as I could, but considering it rained yesterday, and I couldn't get the window to work for a short period makes me want to replace the switch now vs. when it's stuck for good. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
mccorry Posted July 28, 2007 Share Posted July 28, 2007 Mine has been sticking for the past few weeks.... I always have to check it to make sure it returns to the rest position. Link to comment Share on other sites More sharing options...
Legasee Posted July 28, 2007 Share Posted July 28, 2007 mines also been sticking more and more... In Taiwan now... Link to comment Share on other sites More sharing options...
Vimy101 Posted July 28, 2007 Share Posted July 28, 2007 Seems to be mostly 05s having this problem. I wonder if it's age related or a substandard batch of switches or a combination of the two. Link to comment Share on other sites More sharing options...
jerami1981 Posted July 28, 2007 Share Posted July 28, 2007 mine has been sticking for over a year now. i forgot to get it looked at while i had it under warranty. on a side note, it only has the problem with rolling down. In the 30+ times it has happened to me it has never been a problem for longer than 5-10 minutes and it has never been a problem with rolling it up, only down. Link to comment Share on other sites More sharing options...
Legasee Posted July 28, 2007 Share Posted July 28, 2007 So I removed the door panel removed & completely disassembled the switch (really didn't need to) Here’s what I found: The drivers window switch is actuated by a "slide" type switch, while all the other windows, locks, an such are "rocker" type "My" problem was a "plastic pin". Being it's a slide switch, it uses a spring and plastic pin to re-center itself in the pocket. When I opened it up, I thought the bottom of the pin looked a little too sharp. (Pointed) I made it nice and round with a small file. Snapped it back in.... NO GO, same notchy feeling as before. So then I "flattened out" the very tip, leaving slightly rounded sides. BINGO! Works as good as, if not better than new. I have a feeling I'll be doing this job more than once. Sorry no pictures. Notes: There are 5 screws to remove the switch from the back of the door panel. (Looks like 4, but there IS 5) For this particular fix, there is no need to completely disassemble the switch. Remove it from the plastic garnish, and you can pry the driver switch "rocker" off from the top. Be careful not to break the rocker/lever. Don't loose the pin or spring on top of it. The rest is obvious. Good luck! *read all ^, then scrolled up to see where you're located* In Taiwan now... Link to comment Share on other sites More sharing options...
Mongo Posted July 31, 2007 Share Posted July 31, 2007 Yep, me too. it just wants to jump to auto down. Link to comment Share on other sites More sharing options...
