vanjames Posted July 2, 2006 Share Posted July 2, 2006 had my techna-fit lines installed today and both lines for rear calipers are leaking.found one before bleed and the other one started to leak when my mechanic doing bleed.Called Eric from liteswap and no body answer. :icon_mad: not very happy Link to comment Share on other sites More sharing options...
mccorry Posted July 2, 2006 Share Posted July 2, 2006 Did you reinstall the new lines with the old copper washers on the Banjo bolts? You are supposed to re-use the washers... one inside and one outside. Link to comment Share on other sites More sharing options...
magnetic1 Posted July 2, 2006 Share Posted July 2, 2006 had my techna-fit lines installed today and both lines for rear calipers are leaking.found one before bleed and the other one started to leak when my mechanic doing bleed.Called Eric from liteswap and no body answer. :icon_mad: not very happy James, you called Sat. evening on a holiday weekend... Im sorry I couldnt return your call immediately. We do check emails all weekend and I did reply to your email. Where are they leaking from? Like mccorry said, if you dont use all the washers, they will leak (though they do come with new washers). But if it is leaking elsewhere, like from a fitting, then you will need new lines. I gave you the number for Techna-Fit to save time. It'll be much faster for them to ship you a replacement direct if that is the case. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
vanjames Posted July 2, 2006 Author Share Posted July 2, 2006 yes my mechanic did install a washer inside and a washer outside.and the leak is from that "plastic sleeve" which after the elbow fitting.so the leak is from between fitting and line.not from the bolt which attach to caliper. Link to comment Share on other sites More sharing options...
Xenonk Posted July 2, 2006 Share Posted July 2, 2006 is it line overstretched? Keefe Link to comment Share on other sites More sharing options...
vanjames Posted July 3, 2006 Author Share Posted July 3, 2006 thanks for everybody's help. Eric from Brakeswap and Stuart from techna-fit techna-fit will send me new lines asap. Link to comment Share on other sites More sharing options...
bstieritz_GT Posted July 9, 2006 Share Posted July 9, 2006 hmmmm, bad batch maybe?? Or overstretched?? Link to comment Share on other sites More sharing options...
