MTlegacygtx Posted June 24, 2006 Share Posted June 24, 2006 When I bought my LGT, I knew the CEL and cruise lights would be crazy due to stage 2 upgrades. I read a forum describing the 2.2 resistor fix, and expected to do this. However, I downloaded the newest version of the stage 2 map, and installed fixing the problem. Before the fix, the cruise was inoperable. I still have some problems with the cruise after the fix, although it works now. The cruise likes to randomly shut off. I did notice it likes to shut off at the start of a hill climb. Will the resistor fix this? Anybody experience this too? Link to comment Share on other sites More sharing options...
Euclid Posted June 24, 2006 Share Posted June 24, 2006 I don't think this is related to your mods. Check in the warranty forum for threads discussing this. Some cars are having cruise control problems. I know my boss just got back from a trip in his LGT and he said that his cruise control stopped working, and he has no mods. Link to comment Share on other sites More sharing options...
TSiWRX Posted June 25, 2006 Share Posted June 25, 2006 ^ Agreed. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
CombatCQB Posted June 25, 2006 Share Posted June 25, 2006 The neutral switch in the MT toggles by itself causing the cruise control to shut off. The current fix is to remove the switch and file down the copper washer by maybe a hundred of an inch. I have not had a problem since then. Link to comment Share on other sites More sharing options...
MTlegacygtx Posted June 26, 2006 Author Share Posted June 26, 2006 The neutral switch in the MT toggles by itself causing the cruise control to shut off. The current fix is to remove the switch and file down the copper washer by maybe a hundred of an inch. I have not had a problem since then. Thanks guys. Is thıs the fıx perfromed by a Subaru dealer? Link to comment Share on other sites More sharing options...
Jon in CT Posted June 27, 2006 Share Posted June 27, 2006 Thanks guys. Is thıs the fıx perfromed by a Subaru dealer?No. Instead, they'll probably try reflashing your ECU and/or replacing the neutral position switch. Link to comment Share on other sites More sharing options...
