c-lo Posted June 23, 2006 Share Posted June 23, 2006 Just repainted my stock grill, the one coat of satin black wasn't enough, so I resprayed and put on 4 coats. I know the badge comes off, but what's the surface like behind? is it flush? if I put a L7 decal there, would there be a lip around the decal that stuck out? thought maybe removing the badge would improve the lines a little. ultimately I'm thinking about going to an RBS grill or a knock off. but no now. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Hanger Posted June 23, 2006 Share Posted June 23, 2006 There's two things that stick out of the surface that connects to the badge itself, and the surface is maybe 1cm deep with a thin wall that shapes like the badge as i remember ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
c-lo Posted June 23, 2006 Author Share Posted June 23, 2006 are the 2 things I see when I look at the grill from the back what you are talking about? or are there 2 more I'll see when I remove the badge. thinking I may take if off and put the decal in the spot where the badge was. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
