aldouse Posted June 19, 2006 Share Posted June 19, 2006 ok, its official, i'm going to upgrade my endlinks. i've searched throughout the forums already and have already come to the conclusion that my endlinks "might" be THE most probably cause to my "clunking" sound issue. my current setup as follows: - tein h-tech springs - perrin 3-hole rsb @ tightest setting issue: - clunk sound over dips, bumps, minor potholes, and other road obstacles most probable solution time being: - avo rear stabilizer endlinks. now before i jump the gun and buy the endlinks, i just want to confer w/ you guys if the route i am going to go do right now would be the most economical and sound decision to make? or should i take a look at a different branded endlink? should i cut my bumpstops in the rear? or maybe even different approach to this issue all together? i'm not really looking to purchase a different rsb setup to solve the clunking so i'm going to deal w/ this setup as much as i could. any help and advice is greatly much appreciated. thanks. -- yay for the sig! -- my garage! Link to comment Share on other sites More sharing options...
aldouse Posted June 19, 2006 Author Share Posted June 19, 2006 anyone? -- yay for the sig! -- my garage! Link to comment Share on other sites More sharing options...
subiru Posted June 19, 2006 Share Posted June 19, 2006 i shall check the strut top bolt for you. Link to comment Share on other sites More sharing options...
Rommel Posted June 19, 2006 Share Posted June 19, 2006 ^+1 did you double check if the springs are seated correctly Link to comment Share on other sites More sharing options...
gmorris Posted June 19, 2006 Share Posted June 19, 2006 My Perrin rear sway contacted the suspension members over bumps when it was in the center position. I have since moved it to the stiffest and it has lessened the number of clunks but I do still get them. I'd blame the sway bar myself. Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 19, 2006 Share Posted June 19, 2006 I agree with subiru that is is likely your your spring change not to endlinks. Whatever you determine it is please post up and let us know. Link to comment Share on other sites More sharing options...
PGT Posted June 19, 2006 Share Posted June 19, 2006 I'd blame the sway bar myself. So would Perrin. At my urging/prodding, they finally redesigned their crapola of a bar. You should check for things that look like this (no endlinks will fix a bad design): http://i4.photobucket.com/albums/y124/PatagonianGT/115-1578_IMG.jpg http://i4.photobucket.com/albums/y124/PatagonianGT/pic2.jpg Link to comment Share on other sites More sharing options...
PGT Posted June 19, 2006 Share Posted June 19, 2006 I agree with subiru that is is likely your your spring change not to endlinks. Whatever you determine it is please post up and let us know. not the springs man. There's a known issue with the Perrin 3 hole bar. You will get clunks on the control arm - those pics above are from two different cars. Perrin was replacing them with the new two-hole design...not sure if they still will do that since they only carry a one-year warranty. Bottom line....a new swaybar won't cost much more than endlinks. Link to comment Share on other sites More sharing options...
STiSubie109 Posted June 19, 2006 Share Posted June 19, 2006 Sorry to hijack, but i got the same problem with my whiteline adjustable....its clunking on the rear driver side. looks like the endlink is loose? or i bent a bolt...would i be better off to go aftermarket links? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted June 19, 2006 Share Posted June 19, 2006 Sorry to hijack, but i got the same problem with my whiteline adjustable....its clunking on the rear driver side. looks like the endlink is loose? or i bent a bolt...would i be better off to go aftermarket links? I just returned my Whiteline RSB for the clearnace issues. It is not a very good design, and end-links will not solve the problem. Longer end-links on a whiteline makes the bar hit the upper control arm. Stock sized end-links and it hits the lower one. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
