ion Posted May 22, 2006 Share Posted May 22, 2006 I wanted to upgrade my brakes for some upcoming AutoX this summer. I was thinking pads, fluid and Goodridge SS lines. I tried searching and could not find a solid answer - so I figured I would ask: Where is a good place to get them (with a decent price) - also which fluid do you all recommend? Thanks! Link to comment Share on other sites More sharing options...
PhilT Posted May 22, 2006 Share Posted May 22, 2006 I wanted to upgrade my brakes for some upcoming AutoX this summer. I was thinking pads, fluid and Goodridge SS lines. I tried searching and could not find a solid answer - so I figured I would ask: Where is a good place to get them (with a decent price) - also which fluid do you all recommend? Thanks! Got mine from Peter at PLtek, contact him for a good deal. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
whitetiger Posted May 22, 2006 Share Posted May 22, 2006 got mine from tirerack.com they fit great. Pltek is a gret place to purchase them too. Link to comment Share on other sites More sharing options...
praedet Posted May 22, 2006 Share Posted May 22, 2006 brakeswap is another place... Link to comment Share on other sites More sharing options...
Legasee Posted May 22, 2006 Share Posted May 22, 2006 this is gonna be a good mod...some ss brake lines, brake fluid, and more aggressive brake pads ...heard good things about these Goodridge SS brake lines! In Taiwan now... Link to comment Share on other sites More sharing options...
Rommel Posted May 22, 2006 Share Posted May 22, 2006 got mine from Mastro when it first came out Link to comment Share on other sites More sharing options...
edmundu Posted May 22, 2006 Share Posted May 22, 2006 ^^ At the time, they were one of the few that had them coated/jacketed. Link to comment Share on other sites More sharing options...
MDW25gt Posted May 23, 2006 Share Posted May 23, 2006 Motul RBF 600 fluid. Hawk HPS pads. I did pads turned the rotors & fluid last summer. I would like to do the SS lines this year. Keep us posted on your results. Link to comment Share on other sites More sharing options...
hal9e3 Posted May 23, 2006 Share Posted May 23, 2006 ^^ At the time, they were one of the few that had them coated/jacketed. Check with your intended source to make sure they're coated/jacketed - assuming you want them that way. They come both ways, sometimes from the same vendor. Link to comment Share on other sites More sharing options...
ion Posted May 23, 2006 Author Share Posted May 23, 2006 Is it worth having them coated/jacketed or are simple SS lines still better than regular stock ones? Link to comment Share on other sites More sharing options...
driggity Posted May 23, 2006 Share Posted May 23, 2006 Is it worth having them coated/jacketed or are simple SS lines still better than regular stock ones? Its probably worth it as it should add little or nothing to the price (at least thats the way it was when I bought stainless lines for my WRX). The coating helps protect the outside of the lines so that they will last longer. Link to comment Share on other sites More sharing options...
