CMull123 Posted May 14, 2006 Share Posted May 14, 2006 I recently purchased the JDM rain visors and found with the instructions some small metal hangers and clips. Now I've installed rain visors before, but this was on a 92 GMC Sierra, not the hardest install, but there were no clips or hangers. Since all the instructions are in Japanese, I can't really tell what it's wantin me to do with them. Also, it looks like it's tellin me to take part of my trim off and I don't know, since, again, it's in Japanese. The visors themself also have some double stick tape on them which I could handle that install in about 45 seconds, but the directions and hangers just confused me. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted May 14, 2006 Share Posted May 14, 2006 The metal clips go into the body of the car- peel back the weatherstripping and install them, then put the weatherstripping back on. Put the visors on, stripping the backing to the 2 way tape back a little as you go. Link to comment Share on other sites More sharing options...
PGT Posted May 14, 2006 Share Posted May 14, 2006 you need to sort through the clips...there are two types. One gets screwed in place using existing screws. The other clips in place. Pull the weather seal down....before you install them. The double-stick should be on the visor....use the prep pad on the mounting surface. Do a test fit before pulling the tape - you won't be able to move it once you stick it on. The hardest part besides getting the alignment right is reinstalling the weather stripping....be patient. Your fingers will hurt....you have to squeeze it and work it back up into the channel to properly mount. Hope this helps. The first car I did this on took me 45 minutes. The second time through....ten minutes. Link to comment Share on other sites More sharing options...
CMull123 Posted May 21, 2006 Author Share Posted May 21, 2006 I guess what I should have asked in the first place is if I'm using the adhesive, why do I need the clips, and vice versa, if I'm using the clips, why do I need the adhesive? Link to comment Share on other sites More sharing options...
PGT Posted May 21, 2006 Share Posted May 21, 2006 double security. this isn't a hard install. Link to comment Share on other sites More sharing options...
OhBe1 Posted July 14, 2007 Share Posted July 14, 2007 Any tips before I try this tomorrow? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
OhBe1 Posted September 16, 2007 Share Posted September 16, 2007 Finally got them in this AM, now that summer's over... The hardest part was shoving the seals back into place. Tip - Do one side at a time, so you know what the seals are supposed to look like... With these in place, the windows can be cracked open 1/4-1/2" on a Maryland summer day when parked, waiting for the shower in the heat.... 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
DiscoWagon Posted September 16, 2007 Share Posted September 16, 2007 Where did you get them? Price? Pics? Link to comment Share on other sites More sharing options...
nomoreS4 Posted September 17, 2007 Share Posted September 17, 2007 Any tips before I try this tomorrow? I installed mine a long time ago, but I recall it wasn't clear that the clips have to match up with the dimples (holes?) in the visor, so keep that in mind. Link to comment Share on other sites More sharing options...
NutBucket Posted September 17, 2007 Share Posted September 17, 2007 Where did you get them? Price? Pics? Gruppe-S claims to have them IIRC. Link to comment Share on other sites More sharing options...
nomoreS4 Posted September 18, 2007 Share Posted September 18, 2007 Gruppe-S claims to have them IIRC. I bought mine from my local Subaru dealer (Marino's) here in Canada, about 2 years ago, recall paying something like CDN$275 for them, would have to dig up the invoice to get the exact price. I just gave them the part #'s and they ordered them for me, arrived in a week or so. Link to comment Share on other sites More sharing options...
OhBe1 Posted September 21, 2007 Share Posted September 21, 2007 Not difficult, to install, just have to be careful. Another pair of hands helps. Instructions are in Japanese. There's foam tape on the back of the visor. If you rub a finger along the tape, you'll notice there are holes where clips will go. I marked those on the outside with tape, so I'd know where to put the clips. Clean the plastic area above the windows. I used rubbing alcohol. Then pull down the window seals, & put in one large clip (remove screw, put clip in place, reinstall screw). Wipe the plastic with the primer that comes with the visor. Align the visor with the installed clip & slowly pull the covering off the tape that's on the visor. Alignment is important - this tape is sticky, & you can't adjust position after it makes contact. The other pair of hands helps with the alignment. Then put in the 5 smaller clips & put the door seals back in place. The latter is the hard part. Do only one side at a time, so you have something to reference. Properly installed, it won't interfere with the door & window. We haven't tried it driving in the rain, but it looks like you can park with the windows cracked open in a Mid-Atlantic summer day (90degF with unknown chance of rain). 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
