rallispec Posted May 12, 2006 Share Posted May 12, 2006 opinions? is that too far down to be usefull? I have my XM reciever up in the cubby and i'm hesitant about mounting it to the steering column-- so my other option is buying a gauge pod and mounting off the a-pillar. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted May 13, 2006 Share Posted May 13, 2006 that is gtoo small dude Link to comment Share on other sites More sharing options...
rallispec Posted May 13, 2006 Author Share Posted May 13, 2006 it's a small gauge.. i think it might fit. It will definetly fit if i take the dremel to it:icon_twis Link to comment Share on other sites More sharing options...
Hanger Posted May 13, 2006 Share Posted May 13, 2006 i think i've seen someone did it on this forum... posted picture just recently... i'll try searching it ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Hanger Posted May 13, 2006 Share Posted May 13, 2006 yup found it i'm very bored at work...pile my work on my assistant http://www.legacygt.com/forums/showthread.php?t=32519 ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
rallispec Posted May 13, 2006 Author Share Posted May 13, 2006 yup found it i'm very bored at work...pile my work on my assistant http://www.legacygt.com/forums/showthread.php?t=32519 heh.. nice work, thats good to look at, gives me more ideas on what i could do with mine - although i really want the gauge to be flush with the faceplace rather than protrude. Link to comment Share on other sites More sharing options...
Hanger Posted May 13, 2006 Share Posted May 13, 2006 i guess since that dude can connect the gauges there already, it's possible to fit yours into the spot there if your gauges is small enough ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
rallispec Posted May 13, 2006 Author Share Posted May 13, 2006 i am worried about it being difficult to look down and see what it's doing while driving... but honestly it shouldnt be too bad. Link to comment Share on other sites More sharing options...
Hanger Posted May 13, 2006 Share Posted May 13, 2006 might be able to install them with an angel slanted up? sort of a triangular mount to where the ashtray is? ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
ZinFreak Posted May 13, 2006 Share Posted May 13, 2006 opinions? is that too far down to be usefull? I have my XM reciever up in the cubby and i'm hesitant about mounting it to the steering column-- so my other option is buying a gauge pod and mounting off the a-pillar. You'll never be looking down there. Put it on the steering wheel column. It isn't that tough to do. Be well. -Zin 06 LGT LTD GRP 5MT 07 FXT LTD OBP 4EAT Link to comment Share on other sites More sharing options...
rallispec Posted May 13, 2006 Author Share Posted May 13, 2006 fits fine, very easy to see... pictures to follow, and i suck at bondo the bondo! Link to comment Share on other sites More sharing options...
tmat3 Posted May 15, 2006 Share Posted May 15, 2006 I'm the dude who put those two gauges (see pics that Hanger posted). I put two Autometer 52 mm gauges (oil pres. and water temp). You can definitely put three gauges, if you really want. I tried to fit three and it worked, but I didn't want three in there. Because of the location, I installed gauges which I don't need to look at on a regular basis. Oil pres and water temp don't change quickly. I wouldn't put EGT or Boost or A/F (gauges that change readings on a millisecond basis). I have an Autometer vac/boost gauge on the steering column. The gauge on the right is harder to look at when you shift in 3rd or 5th. THat's my only complaint. I'm not all that great at working with plastics. Therefore, I suck at doing creative interior work. I have no patience. So, my easiest solution was put install painted plastic cut-out piece below the opening. Link to comment Share on other sites More sharing options...
rallispec Posted May 15, 2006 Author Share Posted May 15, 2006 cool, thanks for your input. I've got one gauge down there now so that i can keep the stock 12v power source --- i'm not real happy with how clean the install looks though, so when i touch it up i may remove the cigerette lighter to just to keep the smooth lines going. i've found that boost isnt to bad to put down there, but if i were constantly wanting to see it - then yes, it's not a very good location. I just really didnt want something on the steering column. Link to comment Share on other sites More sharing options...
sportwagon Posted May 17, 2006 Share Posted May 17, 2006 i am worried about it being difficult to look down and see what it's doing while driving... but honestly it shouldnt be too bad. that is my problem with that spot! Link to comment Share on other sites More sharing options...
