red beast Posted May 6, 2006 Share Posted May 6, 2006 had a "tinny tinkling" noise coming from the dash for a long time. pushing, pulling, and banging, here and there didn't' solve it. ...it turned out to be the empty cigarette lighter socket, it is loose in it's housing and the metal pieces rub each other making the noise. for now i put the cigarette lighter back in and took away almost all of it. I'll have to have to take the center dash apart to tighten it. hopefully it's a quick and easy fix. Link to comment Share on other sites More sharing options...
NHLEG Posted May 6, 2006 Share Posted May 6, 2006 You cigarette lighter socket was taking a leak in your dashboard? Must have smelled too. Link to comment Share on other sites More sharing options...
red beast Posted May 6, 2006 Author Share Posted May 6, 2006 You cigarette lighter socket was taking a leak in your dashboard? Must have smelled too. i stuff depends under the dash Link to comment Share on other sites More sharing options...
-TT- Posted May 6, 2006 Share Posted May 6, 2006 for now i put the cigarette lighter back in and took away almost all of it. hopefully it's a quick and easy fix. looks like its time for someone to buy a radar detector Link to comment Share on other sites More sharing options...
red beast Posted May 7, 2006 Author Share Posted May 7, 2006 my old gps setup was plugged into the lighter socket the new setup (bluetooth) is powered and stored in the armrest Link to comment Share on other sites More sharing options...
TSiWRX Posted May 7, 2006 Share Posted May 7, 2006 red beast - I have not investigated this fully in our LGTs, but in my old DSMs, from putting in countless starter-buttons, I know that the cancer-stick lighter assemblies are secured at the back/end by a nut - perhaps that has come loose and is causing the rattling when you don't have any "pressure" on the interior of the cylinder? Again, I don't know if the assembly is the same in our LGTs - but it's pretty easy to gain access to that area so it might be worth a look-see. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Spinjockey Posted May 16, 2006 Share Posted May 16, 2006 red beast - I have not investigated this fully in our LGTs, but in my old DSMs, from putting in countless starter-buttons, I know that the cancer-stick lighter assemblies are secured at the back/end by a nut - perhaps that has come loose and is causing the rattling when you don't have any "pressure" on the interior of the cylinder? That's correct it's just a simple nut, fortunately it's a larger one that can be hand tightened (they even ruberized the back for us!) Link to comment Share on other sites More sharing options...
red beast Posted May 16, 2006 Author Share Posted May 16, 2006 i'll have to rip the dash apart again. which means lots of tape to prevent scratches. i'll do it when i install the subie sub Link to comment Share on other sites More sharing options...
scans007 Posted May 16, 2006 Share Posted May 16, 2006 Hmm for the lighter socket? is the 3.0 diff.......I know to get to our lighters in the LGT you just need to 1) Pop your knob off 2) Pop up the trim around it http://www.pimpmyauto.com/STS_Install/DSC00909.JPG http://www.pimpmyauto.com/STS_Install/DSC00894.JPG Once you get that up, just unplug the power go'n to the lighter and play away.....or am I missing something? Link to comment Share on other sites More sharing options...
