leggtnut Posted May 2, 2006 Share Posted May 2, 2006 Not sure if this was posted yet, but I did do a search and didn't find it here. take a look: http://vocuspr.vocus.com/vocuspr30/DotNet/Newsroom/ViewAttachment.aspx?SiteName=Subaru&Entity=PRAsset&AttachmentType=F&EntityID=100391&AttachmentID=ab3856d6-b790-482c-b6ac-1c2ffa71d097 http://vocuspr.vocus.com/vocuspr30/DotNet/Newsroom/ViewAttachment.aspx?SiteName=Subaru&Entity=PRAsset&AttachmentType=F&EntityID=100395&AttachmentID=e3353ed8-609d-4470-9b0f-50bcc6a195c3 a couple of high lights: Engine 4-cylinder, horizontally opposed (Boxer); specially reinforced die-cast aluminum block with semi-closed deck and integral cast iron cylinder liners; aluminum alloy cylinder heads Displacement 2,457 cc (150 cu. in.) Valvetrain Double overhead belt-driven camshafts (DOHC), 4 valves per cylinder, Subaru Active Valve Control System (AVCS) variable valve timing Fuel/Induction/Engine management Sequential multi-port fuel injection (MFI) with multi-spray injectors, Electronic Throttle Control (ETC) system, turbocharger and intercooler Max. boost pressure 13.5 psi (700 mm Hg) Horsepower 243 @ 6,000 rpm (SAE Certified) Torque 241 lb.-ft. @ 3,600 rpm (SAE Certified) Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
jj808 Posted May 2, 2006 Share Posted May 2, 2006 Yup, same specs we heard not to long ago. No change in horsepower and torque from the 05 and 06. The 243 and 241 are due to the changes in the SAE rules/measurment not any reduction by Subaru. Link to comment Share on other sites More sharing options...
gt_ltd Posted May 2, 2006 Share Posted May 2, 2006 subaru.com This Space For Rent Link to comment Share on other sites More sharing options...
rc0032 Posted May 2, 2006 Share Posted May 2, 2006 Moved to news and rumors Link to comment Share on other sites More sharing options...
godwhomismike Posted May 2, 2006 Share Posted May 2, 2006 I wonder if those numbers would've changed if they tested it in Sport # mode Link to comment Share on other sites More sharing options...
BOY Posted May 2, 2006 Share Posted May 2, 2006 Sport# is not designed to add power, its designed to change the throttle response and maybe the powerband... actual output stays the same. Link to comment Share on other sites More sharing options...
RayDhaIn Posted May 2, 2006 Share Posted May 2, 2006 Anybody knows if 07 still has catted uppipe?0-60 & 1/4 numbers?And will the estimated fuel economy change due to the SI-drive? Link to comment Share on other sites More sharing options...
