Francis Posted April 25, 2006 Share Posted April 25, 2006 A few months back I had a set of JL speakers installed in the front doors with a JL e2150 amp under the front driver seat. A couple of weeks ago I purchased a JL Stealthbox sub and a JL e1400 amp. These were installed by a local Tweeter with the amp for the sub mounted under the rear wagon floor. I was unclear where the speaker inputs for the sub amp came from. I thought they might have come from the pre-outs of the front speaker amp but I checked and they are not in use. I discovered that when I turn down the gain for the front amp that it reduces the sound for both the front speakers and the rear sub. It seems that they must have spliced the inputs for the sub to the already amped front speaker wires. Does this make sense as the outputs from the front speakers incorporate a crossover that is set for the mids and tweeters? Any comments or suggestions would be great. Link to comment Share on other sites More sharing options...
Boulderguy Posted April 25, 2006 Share Posted April 25, 2006 Based on what you say it makes zero sense. Then again if the sub signal is sourced from the hi-pass then the sub would be doing almost nothing anyway. So I wonder... Have you actually seen the sub input source? Link to comment Share on other sites More sharing options...
Francis Posted April 25, 2006 Author Share Posted April 25, 2006 I partially pulled up the trim panel on the driver door threshold. The wires going to the sub amp appear to be spliced into the wires for the front speakers. I could not tell if these front speaker wires were coming from the front amp or coming from the radio. It would seem that they must be coming from the front amp on the way to the front speakers due to the fact that when I change the gain on the front amp it changes the volume of the front speakers and the rear sub? Link to comment Share on other sites More sharing options...
Boulderguy Posted April 25, 2006 Share Posted April 25, 2006 you lost me at "front sub." Link to comment Share on other sites More sharing options...
Francis Posted April 25, 2006 Author Share Posted April 25, 2006 Sorry, I meant the front amp. Link to comment Share on other sites More sharing options...
Boulderguy Posted April 25, 2006 Share Posted April 25, 2006 Are you sure your front amp is x-ed over? If so then the above wouldn't make sense, you'd have no sub output. Really all this is conjecture until you climb in there & find out exactly what's going where. Link to comment Share on other sites More sharing options...
mwiener2 Posted April 25, 2006 Share Posted April 25, 2006 sounds like tweeter treated it like a stock setup and grabbed the high level inputs off your front speakers. Take it back and tell them they did it wrong and you want the pre-amp line level RCA outs from the 4 channel amp routed to the RCA line level input on the 2 channel sub amp. And tell them they're a bunch of morons while you're at it. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Boulderguy Posted April 25, 2006 Share Posted April 25, 2006 And tell them they're a bunch of morons while you're at it. Maybe wait til they're finished to say that part... Link to comment Share on other sites More sharing options...
msmith Posted April 25, 2006 Share Posted April 25, 2006 unfrickingbelievable... Please let me know what you find out so I can communicate with the appropriate people at Tweeter. Link to comment Share on other sites More sharing options...
mwiener2 Posted April 25, 2006 Share Posted April 25, 2006 open a can of whoopass msmith!!! My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Francis Posted April 25, 2006 Author Share Posted April 25, 2006 I spoke with Tweeter and they did use the amplified, crossed over signal from the front speaker amp for the inputs for the sub amp. They adjusted the crossover on the front amp so that all of the signal would go through. They have agreed to run RCA's from the unamplified outputs on the front amp to the sub amp tomorrow night. Manville - I will let you know when the issue is resolved. Link to comment Share on other sites More sharing options...
mwiener2 Posted April 25, 2006 Share Posted April 25, 2006 No!!! Bad!!! you want that crossover on the front amp set to highpass. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Boulderguy Posted April 25, 2006 Share Posted April 25, 2006 What a bunch of monkeys. Yes, echo, you want fronts X-ed over. Please proceed as planned with moron comments. Link to comment Share on other sites More sharing options...
Francis Posted April 25, 2006 Author Share Posted April 25, 2006 Once they fix the wiring issue, I will adjust the front crossover so it is on high pass and set around 90. Link to comment Share on other sites More sharing options...
msmith Posted April 25, 2006 Share Posted April 25, 2006 I spoke with Tweeter and they did use the amplified, crossed over signal from the front speaker amp for the inputs for the sub amp. They adjusted the crossover on the front amp so that all of the signal would go through. They have agreed to run RCA's from the unamplified outputs on the front amp to the sub amp tomorrow night. Manville - I will let you know when the issue is resolved. Unfrickingbelievable... I will need to know the specific Tweeter location, name of installer and name of salesperson. Link to comment Share on other sites More sharing options...
Francis Posted April 26, 2006 Author Share Posted April 26, 2006 Tweeter fixed the wiring issue for me last night. They ran RCA's from the Pre-Out on the amp for the front speakers to the speaker inputs on the sub amp. Took them a little while as they had to remove the front driver seat to access the amp for the front seakers. Definitely has a bit more sound now. Still need to fine tune the amp settings. Despite the initial issue with the incorrect wiring, they fixed the issue quickly. The total charge for installing the Stealthbox and sub amp came to just a little over $300 including the wiring. Link to comment Share on other sites More sharing options...
Boulderguy Posted April 26, 2006 Share Posted April 26, 2006 Damn, expensive install. Congrats tho. Enjoy. Link to comment Share on other sites More sharing options...
msmith Posted April 26, 2006 Share Posted April 26, 2006 Still need to know the store location and names of the installer/salesperson. You can e-mail me at "myusername"@jlaudio.com Link to comment Share on other sites More sharing options...
