RobY Posted April 18, 2006 Share Posted April 18, 2006 As you know the Legacy has been given a much more advanced rear multilink suspension compared to its Impreza brethren. This offers many advantages over its Chapman strut counterpart used in the WRX/STi. Advantages: 1) Better camber control. This allows you to use much less static camber as the multilink system adds camber under compression and body roll. 2) Better control over suspension movement, scrub, and toe-in/ toe-out. This is why road going race cars including F1 use them. These advantages allows it to outperform an equally setup chapman system by virtue of better tire control. Disadvantages: 1) Complexity. It is more complex than a chapman strut. 2) Limited suspension movement. A chapman strut allows the wheel to move through a greater range of motion. This is why WRC cars still use them. 3) Difficult to tune if you dont know what you are doing. As to which is better. Given equally capable setups a multilink/ wishbone system will almost always be better on the tarmac. A strut system will be better/ more durable offroad. Part 2: Breaking the Multilink into its component parts. The legacy's multilink is broken down into 4 links. 1) Trailing Link. 2) Upper Lateral Link. 3) Lower Lateral Link. 4) Toe Link. Trailing Link: This link's sole purpose is to localize fore and aft movement in the suspension. It is mounted parallell to the long axis of the car and moves in an arc. The mounting of the fulcrum point relative to the spring provides anti-dive and anti-lift geometry. Because the pivot point isolates movement to one vector it does a better job of controlling fore/ aft movement of the car. Upper Lateral Link/ Lower Lateral link: This is what controls/isolates side to side movement of the wheel and provides camber control. These for the most part are "double wishbones" but are not in a wishbone shape because it does not have to control fore and aft movement like a double wishbone system. The fore/aft isolation of the wishbone has been seperated and given to the trailing link as mentioned above. The upper and lower lateral links are what we call an unequal length arm system. This effects camber control because the longer lower link moves in a larger arc than the shorter upper link. What this means is that the lower arm arcs out more than the upper arm under compression. Tilting the top of the wheel into the car. This is EXCELLENT for handling as it adds camber when it is needed the most for cornering. This allows you to run a lower amount of static negative camber and have camber gain when diving into a corner. This is also why you gain static negative camber when you lower your car. The unequal length concept is so effective that F1 and Champ cars still use it in thier suspensions today. Toe Link: This link effects the toe in/ toe out of the car. Intrestingly it is also the longest arm in our multilink suspension. This means it moves in the widest arc. The toe link is mounted the most rearward in the suspension meaning under compression it will toe the wheel inward. Toe-in is responsible for greater stability at the expense of turn in response and tossability. Toe-out gives you better turn in response but can be very twitchy at speed. It seems like Subaru designed the multilink with saftey in mind and set the toe arc to add toe-in under compression. This makes it very stable and predicatable in the corners but sacrifices the ass end out opposite lock behavior. Thats all for now folks. This is what I gathered from staring at my suspension for a bit. Link to comment Share on other sites More sharing options...
RobY Posted April 18, 2006 Author Share Posted April 18, 2006 How Suspension Mods Effect the Rear Multilink Suspension: Part 1: Adjustable Lower Lateral Links. Providing you don't take this to the extreme this actually kills 3 birds with one stone. 1) The most obvious is that it adds more static negative camber. 2) Dynamicly it ALSO increases the diffrence in the lower arm and the upper arm of the "wishbone" system. This means that it will add even MORE camber at a greater rate than stock under compression. 3) It decreases the rate of change in the toe-link. Because the link is longer, it decreases the diffrence in the arches of lower lateral link and the toe link so that they move in a more similar arch. This means the suspension toes in LESS under compression. This will probably make the car slightly more tossable at a slight expense to high speed stability. If setup right this is a very worthwhile mod. Link to comment Share on other sites More sharing options...
Th3Franz Posted May 8, 2006 Share Posted May 8, 2006 Good posts. I'm toying with the idea of making this a sticky or adding the info to the tech thread. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
highwaydrifter Posted May 8, 2006 Share Posted May 8, 2006 doo eeet Link to comment Share on other sites More sharing options...
mccorry Posted May 8, 2006 Share Posted May 8, 2006 Nice post! Link to comment Share on other sites More sharing options...
panamajack Posted May 8, 2006 Share Posted May 8, 2006 I need a diagram. Link to comment Share on other sites More sharing options...
goneskiian Posted May 8, 2006 Share Posted May 8, 2006 I need a diagram. +1 Link to comment Share on other sites More sharing options...
Tommyh Posted May 23, 2006 Share Posted May 23, 2006 <bump for a diagram> Martin Luther - "Who loves not women, wine and song remains a fool his whole life long." EL4NFZT7 Link to comment Share on other sites More sharing options...
teK-- Posted November 4, 2009 Share Posted November 4, 2009 Roby this is one of the most informative posts I have read in this whole forum. Nice work, it has allowed me to learn a lot more about how my rear wheels hook up to the tarmac. Thankyou Link to comment Share on other sites More sharing options...
goneskiian Posted November 4, 2009 Share Posted November 4, 2009 Woah! Nice old thread bump there teK! I had to reread it because it's been so long I forgot I read it the first time! Link to comment Share on other sites More sharing options...
FPerron Posted November 4, 2009 Share Posted November 4, 2009 (edited) OK, please explain again why I got more understeer when I added adjustable lower links and dialed in more negative camber? I assumed it was because I got a better contact patch in the rear and thus better adhesion under cornering. You seem to be saying that lengthening the lower control arm (increasing neg camber) will reduce progressive toe in during compression (cornering) and thereby increase tossability (oversteer). Edited November 4, 2009 by FPerron Link to comment Share on other sites More sharing options...
SATSFYD Posted November 6, 2009 Share Posted November 6, 2009 Good information. Well written, Thanks. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
anarchyx34 Posted October 31, 2019 Share Posted October 31, 2019 I know I'm bumping an ancient thread but found it incredibly informative. I'm having an issue with excess camber and toe-in on my 2005 Wagon. Alignment shop can't get it right and the toe adjustments are at their max. Rear end appears to sit somewhat low so according to OP this all makes sense and it's working as designed. I'm probably going to see if saggy butt spacers fix this but I have one burning question. Say you take a brand new Legacy from the factory, with perfect ride height and alignment. Put 2 people in the back and some luggage for a road trip. Now the suspension squats a few inches, and then what... Excess negative camber and toe-in? Isn't that going to needlessly eat tires? Isn't that kind of a dumb design? Link to comment Share on other sites More sharing options...
Enduroelite Posted January 27, 2020 Share Posted January 27, 2020 Have you been able to get your car in order, what needs to be done? Link to comment Share on other sites More sharing options...
Nonamedude Posted January 29, 2020 Share Posted January 29, 2020 Have you been able to get your car in order, what needs to be done? There is a massive thread about ghost walking on the subaru outback forums. Likely the person above you had an issue with worn suspension. That is a theme with more recent "can't get my car aligned" posts. Worn bushings and worn struts or springs change the angles and the vehicle settles into a new position and since only the toe is adjustable from the factory in the rear, it messes with stuff. The answer usually should be "all new everything" but ends up being Whiteline KTA124 to give more adjustability in the camber and toe. Link to comment Share on other sites More sharing options...
