SLegacy99 Posted April 17, 2006 Share Posted April 17, 2006 Its an oil consumption thread! YAY! So who uses as much oil as I do? And where is it all going? This is my second EJ25 to do this. I generally add anywhere from 1.5 - 2 quarts between oil changes. Link to comment Share on other sites More sharing options...
The B4 Posted April 17, 2006 Share Posted April 17, 2006 Its an oil consumption thread! YAY! So who uses as much oil as I do? And where is it all going? This is my second EJ25 to do this. I generally add anywhere from 1.5 - 2 quarts between oil changes. What are you doing wrong?! My oil is always spot on! [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Opie Posted April 18, 2006 Share Posted April 18, 2006 What grade/type of oil? If you are losing that much I would be using a 5w40 or a 10w30 and see if it improves... Alos check your PCV valve, if it's clogged your oil consumption will increase. Link to comment Share on other sites More sharing options...
deneb Posted April 18, 2006 Share Posted April 18, 2006 I see you're drving a 99 LGT? Or is this issue happening on an 05-06? If this is a 99 LGT, how many miles are on the motor? How many miles between oil changes? Link to comment Share on other sites More sharing options...
donswhitegt Posted April 18, 2006 Share Posted April 18, 2006 My 03 legacy used about that much. My 06 is much better. Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 18, 2006 Author Share Posted April 18, 2006 Well I use Mobil 5W-30. This happened to both my '96 and '99 EJ25s. I am currently at 82,000 miles. Link to comment Share on other sites More sharing options...
AWD_Rules3830 Posted April 18, 2006 Share Posted April 18, 2006 i will check back and report in 800 miles ... so far no leaks ... soo good lol I love my car ... basically. Link to comment Share on other sites More sharing options...
melayout Posted April 18, 2006 Share Posted April 18, 2006 Statistically, the vast majority of oil consumption complaints from Subaru owners was from using Mobil 1 5W-30. Switch to Mobil 1 10W-30 or a 5W-40 or 10W-40, especially in the summer I keed I keeed Link to comment Share on other sites More sharing options...
AWD_Rules3830 Posted April 18, 2006 Share Posted April 18, 2006 Statistically, the vast majority of oil consumption complaints from Subaru owners was from using Mobil 1 5W-30. Switch to Mobil 1 10W-30 or a 5W-40 or 10W-40, especially in the summer Dont most subaru owners use mobil 1, :lol:, i mean that is typically what dealers sell hahaha I love my car ... basically. Link to comment Share on other sites More sharing options...
deneb Posted April 18, 2006 Share Posted April 18, 2006 I don't think dealers 'typically' sell M1 do they? I know mine doesn't. FWIW my latest oil change/refill consisted of 1.5 qts Chevron synthetic and 3 qts. Chevron dino (5W30), and very little oil used, it's barely below the F dot now on my dipstick with 4.5 k miles on the oil. I was seeing 1/2 - 1 qt between oil changes with M1 (both 5W30 and 0W40) when I used it. Been using either Havoline or Chevron since 21k miles (now at 34.5k) and no issues so far and less oil consumption than M1. Could be just that my motor wasn't fully broken in till recently and that's why my consumption has been down as opposed to the oil I put in the crankcase, but there are quite a few reports of oil consumption with M1. Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted April 18, 2006 Share Posted April 18, 2006 time for a 05 legacy Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 18, 2006 Author Share Posted April 18, 2006 time for a 05 legacy Well maybe the engine....and heated seats Link to comment Share on other sites More sharing options...
