Jeff_B Posted April 9, 2006 Share Posted April 9, 2006 I was walking into the store today and I saw a new Outback in the lot, it had 17's with 225-55-17's and I got very jealous of all that tire, the 215-45-17's don't put much rubber between the rims and the road - or lack there of road, ie-potholes:). So the question is, with the difference of ride height and all, with the Outback 225-55-17's fit a LGT with stock suspension w/o rubbing? Question 2, can the speedo be recalibrated to stay correct? Like is there a speedo gear that can be gotten from an Outback that can be swapped into my LGT to keep the speedo correct? Let me know if anyone has tried any of this. Thanks, Jeff Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted April 10, 2006 Share Posted April 10, 2006 There should be a speedometer correction setting in the ecu. the Subaru diagnostic tool (dealer service department should have one...) should be able to change that setting. There is no gear, as the computer determines the speed from the ABS sensors, and feeds it to the CAN-line driven spedometer. no mechanical parts, aside from the ABS sensors. Just to verify, you may want to use a tire calculator and check the diameters for the Outback wheel and tire, versus the 2006 LGT Spec B, which has 215/45-18 tires... IIRC. I would think the 55 series 17s would be similar overall diameter, and the Spec B would then come with the setting set the same as the Outback. Link to comment Share on other sites More sharing options...
drewster Posted April 10, 2006 Share Posted April 10, 2006 had some free time... here you go Link to comment Share on other sites More sharing options...
bemani Posted April 11, 2006 Share Posted April 11, 2006 Good way to extend your 36000mile warranty. Link to comment Share on other sites More sharing options...
