nwroller Posted August 30, 2004 Share Posted August 30, 2004 1) Has anyone found out a way to disable the seat belt chime? 2) When I try to unlock the doors using the key fob I press it twice to get all the doors, but it does not work. I have to press it a 3rd and 4th time before they all unlock. Am I doing something wrong? Thanks. Link to comment Share on other sites More sharing options...
DEI99662 Posted August 30, 2004 Share Posted August 30, 2004 [quote name='nwroller']1) Has anyone found out a way to disable the seat belt chime? 2) When I try to unlock the doors using the key fob I press it twice to get all the doors, but it does not work. I have to press it a 3rd and 4th time before they all unlock. Am I doing something wrong? Thanks.[/quote] For the seatbelt chime go here: [url]http://www.legacysti.com/viewtopic.php?t=2096[/url] For the key fob, I would take it to the dealer and see if it needs a new battery. Does the other key fob work for you? Or do you have the same problem? If so, it might be the "brain." Link to comment Share on other sites More sharing options...
chinchy Posted August 30, 2004 Share Posted August 30, 2004 You could check the Interior forum. If you don't want to here's a link: [url]http://www.legacysti.com/viewtopic.php?t=2096&postdays=0&postorder=asc&start=45[/url] Check the post near the bottom of the page by Throttlejockey. For the remote unlock, you may be pushing the buttons too fast. I tried double pressing the button, but it doesn't work for me either. You have to press the unlock, and then after the lights flash and it chirps, press it again. Unless you're already doing that, then maybe something is broken. Link to comment Share on other sites More sharing options...
Tide Posted August 30, 2004 Share Posted August 30, 2004 moved to warranty issues and problems forum. Link to comment Share on other sites More sharing options...
Ken S Posted August 30, 2004 Share Posted August 30, 2004 Have you tried the spare fob to see if it does the same thing? If yes, then it could be either you are doing the second press too soon or there could be a problem with the alarm head unit. Ken Link to comment Share on other sites More sharing options...
nwroller Posted September 9, 2004 Author Share Posted September 9, 2004 we were just clicking the unlock button too quick. Thanks for your help. Link to comment Share on other sites More sharing options...
