CombatCQB Posted March 24, 2006 Share Posted March 24, 2006 I was monitoring the A/C compressor to see how often the auto climate control would use it since the A/C indicator is not that helpful. I found that even when it's 35 degrees outside, the A/C will turn on intermittantly even if the desired temp is 71. Can we use data logging to: 1) measure how much throttle lag we have or how the ECU translate pedal movement? 2) capture an instance of the infamous engine surge? Link to comment Share on other sites More sharing options...
f1anatic Posted March 24, 2006 Share Posted March 24, 2006 Acceleration times...0-60 ? Link to comment Share on other sites More sharing options...
derffred Posted March 24, 2006 Share Posted March 24, 2006 Stack ST8600 Steering Wheel Display -- Bimmerworld Online Store Link to comment Share on other sites More sharing options...
schwinn Posted March 24, 2006 Share Posted March 24, 2006 I was monitoring the A/C compressor to see how often the auto climate control would use it since the A/C indicator is not that helpful. I found that even when it's 35 degrees outside, the A/C will turn on intermittantly even if the desired temp is 71. FYI - AC cyling is intended to keep the AC compressor lubricated through the colder seasons. This way, it doesn't fail the next summer. Many cars do this these days. It's a feature Link to comment Share on other sites More sharing options...
