kleggo Posted March 10, 2006 Share Posted March 10, 2006 Hey, i just bought my 4th Subie, a 2006 LL beanie. it's my 2nd OBK and i've had 2 Legacy wagons previously. initial inpression = it'll be a highway cruising beast, but not a corner carver (big surprise)! If i had to choose one word for it's handling, i'd consider............. ponderous. the weight of the H6 is noticeable. Since 90+ % of my driving will be california FWY cruising, this should be a marriage made in car heaven. On to the Questions 1. the ignition key illumination ring light flashes at ~ 1 Hz when the ignition is in the run position. headlights can be on or off= no difference. I can't believe this is an intended feature ????????? 2. Is the SET button for clock adjust supposed to be illuminated when the headlights are on? Mine is NOT. no Nav system in this car thanks kleggo Link to comment Share on other sites More sharing options...
Jon in CT Posted March 10, 2006 Share Posted March 10, 2006 If i had to choose one word for it's handling, i'd consider............. ponderous. the weight of the H6 is noticeable.Yeah. The LL Bean wagon weighs 20 lbs more than the Legacy GT Limited wagon. Link to comment Share on other sites More sharing options...
Scotty Posted March 10, 2006 Share Posted March 10, 2006 2. Only the LGT has the sun button to turn the dash lighting to daylight setting when the headlights are on. Those with standard guages don't need this feature since you can see your gauges in the daytime. Link to comment Share on other sites More sharing options...
kleggo Posted March 10, 2006 Author Share Posted March 10, 2006 2. Only the LGT has the sun button to turn the dash lighting to daylight setting when the headlights are on. Those with standard guages don't need this feature since you can see your gauges in the daytime. ___________________________________________________________________ thanks, that's interesting but how does that answer question # 2? be safe kleggo Link to comment Share on other sites More sharing options...
RabidMonk Posted March 10, 2006 Share Posted March 10, 2006 1. Mine does not flash. Don't know what could be causing yours to do so. (interested to find out) 2. 'SET' button is not illuminated, at least not on my LGT. Link to comment Share on other sites More sharing options...
PeterJMC Posted March 10, 2006 Share Posted March 10, 2006 2. 'SET' button is not illuminated, at least not on my LGT. +1 Link to comment Share on other sites More sharing options...
rpm6500 Posted March 10, 2006 Share Posted March 10, 2006 1 - Mine does not flash either2 - the set button does not light up ummm, Sun button? Am I missing something? I understand what this is supposed to do but I have never seen one in my car... Are you talking about the sensor on the dash? Link to comment Share on other sites More sharing options...
ilh Posted March 10, 2006 Share Posted March 10, 2006 ummm, Sun button? Am I missing something? I understand what this is supposed to do but I have never seen one in my car... Are you talking about the sensor on the dash?The 06s don't have it. Your only choice is to turn the dash illumination roller switch all the way up. Link to comment Share on other sites More sharing options...
Scotty Posted March 11, 2006 Share Posted March 11, 2006 I think I miss read the initial post. My bad. Link to comment Share on other sites More sharing options...
