rallynut555 Posted March 8, 2006 Share Posted March 8, 2006 Just got new tires mounted on the car today and the front brakes are not squealing. Brakes are 1 month old Bobcats that have never squealed til today. What should I look for when I inspect the caliper(s)? Link to comment Share on other sites More sharing options...
edmundu Posted March 8, 2006 Share Posted March 8, 2006 Did you have the rotor's replaced at the same time? If not, were they cut/resurfaced? Had you already performed the pad bedding-in procedure? Describe the squealing... Metal on metal squeal, or a metal fork on a dinner plate squeal? The pads are ceramic based, and if you have the latter it has to do with bedding into the rotor. If it is the former, then whoever installed them may not have reused the rubber coated shims, or didn't use sufficient anti-squeal paste. Link to comment Share on other sites More sharing options...
rallynut555 Posted March 8, 2006 Author Share Posted March 8, 2006 No, kept the old rotors but I did bed in the pads as instructed. I guess the sound is like fork on plate squeal. Still strange that the squeal happened after remounting the tires. Link to comment Share on other sites More sharing options...
rallynut555 Posted March 9, 2006 Author Share Posted March 9, 2006 Seems that the new pads are making the sound. Gonna try some anti-squeal paste this weekend. Link to comment Share on other sites More sharing options...
Xenonk Posted March 9, 2006 Share Posted March 9, 2006 check the clips, see if the retainer clip is grinding on the rotor surface.. Keefe Link to comment Share on other sites More sharing options...
iyalla Posted March 9, 2006 Share Posted March 9, 2006 Make sure they didn't over torque the wheel lugs. Link to comment Share on other sites More sharing options...
rallynut555 Posted March 9, 2006 Author Share Posted March 9, 2006 check the clips, see if the retainer clip is grinding on the rotor surface.. i'll take a look. but if this was the case, wouldn't i hear the squeal even when i'm not braking? Link to comment Share on other sites More sharing options...
Xenonk Posted March 9, 2006 Share Posted March 9, 2006 pads can move/shift the retainer clips too.. afterall, the pads are just resting on them Keefe Link to comment Share on other sites More sharing options...
