rizenx Posted March 2, 2006 Share Posted March 2, 2006 I was offered a k&n typhoon for $200 plus install, is this the best intake for a stick gt? Link to comment Share on other sites More sharing options...
rallispec Posted March 2, 2006 Share Posted March 2, 2006 It's a good intake. ALthough a lot of people here are going to tell you not to run an aftermarket intake with out a custom ECU tune.. THe intake could potentially through off your MAF readings and cause the engine to run lean, causing knock. use at your own risk i suppose. Link to comment Share on other sites More sharing options...
rallispec Posted March 2, 2006 Share Posted March 2, 2006 BTW, i would not pay to let somebody else install it.... you're talking probably the easiest aftermarket part to install... ever. easily done by n00bs in under an hour. Link to comment Share on other sites More sharing options...
wukindada Posted March 2, 2006 Share Posted March 2, 2006 200 including tax is a VERY good price;) Install it yourself.....15min job....very simple! Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
mkalbarc Posted March 2, 2006 Share Posted March 2, 2006 I vote against it... Why? Because of things I have read. Do a search before you drop the bones on one. Link to comment Share on other sites More sharing options...
Jon in CT Posted March 2, 2006 Share Posted March 2, 2006 I was offered a k&n typhoon for $200 plus install, is this the best intake for a stick gt?It appears you live in California so you ought to be aware the K&N Typhoon intake kit doesn't have an EO# that covers a 2006 Legacy GT. Subaru's new SPT intake will have an EO# for your Legacy when it comes out in a month or two. Link to comment Share on other sites More sharing options...
My 05 GT Posted March 2, 2006 Share Posted March 2, 2006 Ya know, if Subaru would have used a Karman MAF this wouldn't be a problem. Link to comment Share on other sites More sharing options...
rallispec Posted March 2, 2006 Share Posted March 2, 2006 ']It appears you live in California so you ought to be aware the K&N Typhoon intake kit doesn't have an EO# that covers a 2006 Legacy GT. Subaru's new SPT intake will have an EO# for your Legacy when it comes out in a month or two. EO#? does that have to do with emmissions testing? Link to comment Share on other sites More sharing options...
mccorry Posted March 2, 2006 Share Posted March 2, 2006 I bought one.... and then sold it.... 10% lower MAF readings with the K&N... which caused slight knock with stg 1 and stg 2 maps. On a stock tune, you're probably fine.... Link to comment Share on other sites More sharing options...
CFar Posted March 3, 2006 Share Posted March 3, 2006 Got one, love it, no problems, logged it and found it ran safe. Do a search though, very popular question Link to comment Share on other sites More sharing options...
rizenx Posted March 7, 2006 Author Share Posted March 7, 2006 i was planning on getting the cobb stage 1 and 2 without a doubt, but if this k&n intake causes knock and if it doesn't work well with the AP ECU then what does?? Does Cobb Make a nice Intake? Link to comment Share on other sites More sharing options...
mkalbarc Posted March 7, 2006 Share Posted March 7, 2006 not sure. check their website cobbtuning.com Link to comment Share on other sites More sharing options...
TSiWRX Posted March 7, 2006 Share Posted March 7, 2006 The Cobb intake for the LGT application is still pending release. And no, Cobb specifically does not recommend the use of *any* aftermarket intake with any of their "off-the-shelf" AP maps - only with custom maps is such use recommended. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
