turboman38 Posted February 27, 2006 Share Posted February 27, 2006 Had my ECM reflashed at the dealership to take care of the studder. It made NO difference what so ever. Car still studders. Anybody had anything else done to their car to solve the studder problem? Link to comment Share on other sites More sharing options...
psucaptainkickass Posted February 27, 2006 Share Posted February 27, 2006 Get an AP and flash to Stage 1. That did the trick for me. Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted February 27, 2006 Share Posted February 27, 2006 Talk to a local turner and see if they can reflash you to Stage 1 temp and then back to stock. Usually fixes the issue. Link to comment Share on other sites More sharing options...
emlevins Posted February 28, 2006 Share Posted February 28, 2006 Do a search and you'll find many threads on this. Bottom line - SOA reflash doesn't do the trick and neither does an AP reflash (for many of us that is - there are exceptions). What you will find is that after a reflash the stutter will disappear...for while...and then return. 05 SWP Legacy GT Limited (aka "Pearl")- 5MT AP - Stage 2 Protuned (238/284) - wife driven 07 BMW 335xi Link to comment Share on other sites More sharing options...
tintinet Posted February 28, 2006 Share Posted February 28, 2006 TDC stage 1 map. So far, so smooth! Link to comment Share on other sites More sharing options...
psucaptainkickass Posted February 28, 2006 Share Posted February 28, 2006 Talk to a local turner and see if they can reflash you to Stage 1 temp and then back to stock. Usually fixes the issue. Agreed. The first time I tried out the AP it was in a temporary situation. I used it for a weekend, and then reverted back to stock using the AP. Maybe the "stock" AP map is just "right"? After that (100s of miles later mind you), there was little to no stutter in my car. Then again, my car also cranks right away on the first try after using the AP, so maybe I am special . Try out a local tuner's then revert to stock, see if that doesn't help things out. Otherwise: God I love that new emoticon!!! Link to comment Share on other sites More sharing options...
turboman38 Posted February 28, 2006 Author Share Posted February 28, 2006 I have an access port here. I just have not loaded it yet. Guess I need to get to it. Hopefully it will solve the problem. Link to comment Share on other sites More sharing options...
06Leg Posted February 28, 2006 Share Posted February 28, 2006 Does this "stutter" not apply to the 2.5i NA? I don't notice any stutter yet. I only notice that the automatic holds the gears longer (when NOT in Sport mode even) than any other automatic I have driven. Link to comment Share on other sites More sharing options...
psucaptainkickass Posted February 28, 2006 Share Posted February 28, 2006 Correct, this stutter is only present on the LGT. Link to comment Share on other sites More sharing options...
crash Posted February 28, 2006 Share Posted February 28, 2006 Has anyone that experienced the studder had it go away after a clutch replacement? I drove my friends LGT 5sp the other day and his studder is virtually gone (he had his clutch replaced around 11k miles under warranty).... Of course I never drove his car before the clutch work was done, but my car studders like that dude on Howard Stern, and his doesn't.... Link to comment Share on other sites More sharing options...
tintinet Posted February 28, 2006 Share Posted February 28, 2006 Some have claimed their stutter simply went away after a few K miles. I had a provokable, fairly consistent stutter, diminished but still present with Cobb stage 1 map (up to 2K miles), until I loaded the TDC stage 1 map. Link to comment Share on other sites More sharing options...
