hogmeat Posted February 4, 2006 Share Posted February 4, 2006 OK, I got a door ding (%^#@!) and a small paint chip....i've noticed the is slowly turning into a bigger chip..... Help! Any ideas here? What's a poor man to do?? I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
c-lo Posted February 4, 2006 Share Posted February 4, 2006 ocdetails would be a good one to answer this, but I a short term fix to prevent it from getting bigger (and depending how deep the chip is) you could put a coat of clear nail polish on. I myself would like to know a long term fix too because I have a chip in the hood. it's small, but I'd like to see it go away. I could use touch up paint, but not sure how well it would go on. Have you checked out the paintscratch.com website? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
OCDetails Posted February 4, 2006 Share Posted February 4, 2006 PremiumAutoCare.com has a good guide to fixing paint chips. Langka has a bit of a learning curve, but you can do some pretty flawless touch up work with it once you get the hang of it. I would practice on something before you try it on your car. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
rallispec Posted February 4, 2006 Share Posted February 4, 2006 i have a nasty chip in my front fender that i've got figure out a solution for as well.... (currently using a bit of clear nail polish to protect it) it's going to require more than paint though -- I was hit by a rock on the highway and it left a nasty dent to match the scratch. Link to comment Share on other sites More sharing options...
