jnd121 Posted January 16, 2006 Share Posted January 16, 2006 Does anyone else get a whistling type sound when starting up their LGT? I was figuring it has to do with the turbo, but I wanna make sure. Link to comment Share on other sites More sharing options...
Chappy Posted January 16, 2006 Share Posted January 16, 2006 when its really cold I get that as well..Once its warmed up it goes away. Link to comment Share on other sites More sharing options...
jnd121 Posted January 16, 2006 Author Share Posted January 16, 2006 Yes...it's only when it's cold. THANKS! Link to comment Share on other sites More sharing options...
mechdiff Posted January 16, 2006 Share Posted January 16, 2006 Yes I get that on cold days. When I turn it to the on position without cranking it over I can hear it, not sure what it is, perhaps the climate control fan? It's almost like a whoop whoop sound. Link to comment Share on other sites More sharing options...
melayout Posted January 16, 2006 Share Posted January 16, 2006 Is it during the guage sweep and right before you actually turn the key to ignition? If that's so, then it's from the fuel pressure regulator under the hood. TSB @ http://thel7.com/TSB/09-41-05.pdf The Search ball says : http://legacygt.com/forums/showthread.php?t=21794 http://legacygt.com/forums/showthread.php?t=20588 http://legacygt.com/forums/showthread.php?t=2556 I keed I keeed Link to comment Share on other sites More sharing options...
mwiener2 Posted January 16, 2006 Share Posted January 16, 2006 Mine does it too when it's cold sometimes. Only does it for like a sec right after it cranks and turns over. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
elbarto74 Posted January 16, 2006 Share Posted January 16, 2006 its the fuel pump regulator priming up, you can get it replaced if it annoys you but so far most people say there isn't anything really wrong. Though there is a TSB about it. It's just your Leggy being happy in the morning...whoop whoop whoop.... Link to comment Share on other sites More sharing options...
jnd121 Posted January 16, 2006 Author Share Posted January 16, 2006 Thanks! On a side note, what is a TSB? Link to comment Share on other sites More sharing options...
melayout Posted January 16, 2006 Share Posted January 16, 2006 Technical Service Bulletin I keed I keeed Link to comment Share on other sites More sharing options...
elbarto74 Posted January 16, 2006 Share Posted January 16, 2006 technical service bulleton..... take it to your dealer if it gets annoying they have to replace it (if they can replicate the sound....) under warenty. Takes a few days though. BTW I cant spell gooder...so no flames... Link to comment Share on other sites More sharing options...
VXCL Posted January 17, 2006 Share Posted January 17, 2006 mine does the exact same thing after start up on a cold day. sometimes it goes for a good 20 secs. then it goes away. though it may be an upipe leak. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted January 17, 2006 Share Posted January 17, 2006 I'm used to it and it's actually kinda cool. Link to comment Share on other sites More sharing options...
PhilT Posted January 17, 2006 Share Posted January 17, 2006 It shows that your car is happy and glad to see you again Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mwiener2 Posted January 17, 2006 Share Posted January 17, 2006 i always thought it was the hamster in the cage waking up My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
