SWortham Posted January 21, 2006 Share Posted January 21, 2006 Ted, With my Hyundai at the time, I had plus two aftermarket wheels weighing in at 22 pounds each and some wider, heavier, grippier summer tires (both the tires and wheels were much heavier than stock). And there were plenty of times when I actually could not lock up the wheels if I wanted to with the stock brakes, even before brake fade was induced. And so obviously I wasn't satisfied with the OEM 10.1" brakes. So I upgraded to larger 11" OEM brakes from a Tiburon, and it wasn't until then that I could say that it was the tires and not the brakes holding back the braking performance. By the way, I have read StopTech's articles. The brake bias is definitely a serious issue not to be overlooked. Link to comment Share on other sites More sharing options...
1max2nv Posted January 21, 2006 Author Share Posted January 21, 2006 Yeah..I'm friends with Mark. I still have my maxima. I just recently got a 05 LGT Limited and came on here to get some ideas on mods. 1max2nv... you wouldnt happen to be a friend of "1cl2nv" would you? He mentioned once that he had a friend w/ a Maxima with those plates... Link to comment Share on other sites More sharing options...
