Jaxx Posted January 2, 2006 Share Posted January 2, 2006 is any one else having trouble with the front spring top hats rotating and causing clunking? i have to jack my car up an realign the springs and top hats about every 3-4 months any one else? Link to comment Share on other sites More sharing options...
Opie Posted January 2, 2006 Share Posted January 2, 2006 What springs are you running? Usually when that occurs the spring top hat was not aligned on the strut correctly. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted January 2, 2006 Share Posted January 2, 2006 usually^ the spring may not be seated properly in the first place, but thats kind of hard to do Link to comment Share on other sites More sharing options...
jah64 Posted January 3, 2006 Share Posted January 3, 2006 Mine have also been clunking lately, intermittently too, I can't repeat it. I have Swift Sport Machs and Swift sway bars. Not sure what is that is clunking though, How can the top hats rotate? Link to comment Share on other sites More sharing options...
Jaxx Posted January 3, 2006 Author Share Posted January 3, 2006 currently h-techs but had the same proublems with progress at full extension they (both springs and hats) can be rotated quite easly when it gets mis aligned it get reallllly misaligned thus the clunking Link to comment Share on other sites More sharing options...
hifiandmtb Posted January 3, 2006 Share Posted January 3, 2006 This sounds like exactly what happens when you don't run properly "captive" springs. Your springs don't seem to be properly matched to the shock. The shock at full stretch should hold the spring in tension - quite a bit of tension. If the top hat/spring is rotating, you need to shorten your shock shaft...which is rather difficult when running OEM shocks. For example, Bilstein offer two shock types - B6 Sport & B8 Sprint. B6 can handle mild lowering, but the B8 has a shorter shaft for more extreme lowering. Link to comment Share on other sites More sharing options...
jah64 Posted January 13, 2006 Share Posted January 13, 2006 I just jacked up the car and rotated the spring so it sit properly in the perch. Not hard to do. Jaxx what is the alignment feature for the top hat? Waiting for the crunch crunch. Link to comment Share on other sites More sharing options...
