Shift points for 5EAT 300whp
algol
I have a 2005 Legacy GT 5EAT. The car is running a VF52 turbo, new fueling, down-pipe, and up-pipe. The transmission has been rebuilt by IPT. The only issue I have with the car is that the TCU doesn't seem to know when to shift in automatic mode. It tries to shift 1st and 2nd gear too late so that it hits the limiter under WOT. The car shifts nicely in manual mode. There is no mechanical issue anyone can recognize. It's just the computer doesn't seem to know when to shift the car given the big HP increase over stock. Any advice is welcome. I don't know how to change the shift points. I know though that there are others with 5EATs running even more HP.
Without someone being able to reflash the TCM you're kinda stuck with what you have. It may even be an adjustment the driver must make for the car, instead of WOT... try like... 90%.
Resetting the TCM puts it back to default values.  It's receiving inputs from the ECM it's not expecting so it starts to adjust for those funny inputs and now here we are.
Are you tuned?
Are you tuned?
Do you know how to reflash the TCM?
AFAIK, the TCM is not flashable.  You may want to look into an upgraded valve body if available it may help.  Your tuned ECM is giving the untuned TCM inputs it's not expecting and is doing its best to make it work. An unfortunate byproduct of tuning and upgrading an automatic, if you google you'll find it's not just you.  If you put your car back on a stock tune does the transmission behave normally? If it still acts up then it's not the tune and you have another issue.
I turbocharged my 2001 GC-RS with an auto. If I wanted to drive it spiritedly I had to shift manually, otherwise it was already in third/"fourth" gear by the time we were across a normal sized intersection, acted like a CVT.
Yea, manual mode works much better and is quite fun. Shifts are very firm and quick if you don't count the computer being slow to start the shift. But I know that some people don't have these issues with automatic mode, even though they are running more power.
You may want to pop into a dealer and see if your TCM has any updates available. When I got my 3.6R i thought it was very boring, but an ECM/VDC update woke it up and it's a blast to drive now.
Thanks for that idea. The dealer replaced the valve body 5 years ago. So, I kind of doubt anything new is out. But I need to go to the dealer to get a part anyway, so I'll inquire.
Most wouldn't think to look for a TCM update unless it was a line item on the RO. It's a long shot since the car is getting up there in age but worth a try.
You were right that the tuning was confusing the TCU. We reset the DBW tables and the TCU memory. It’s now working. Hopefully that continues!
