silverton Posted February 3 Share Posted February 3 daniel stern is a boss 1 Link to comment Share on other sites More sharing options...
EloM Posted February 3 Author Share Posted February 3 Well, as its been stated, the output between the drl & the lb is not much, so a bulb of higher lumen output is the only option here. I'll keep an eye out for a better bulb, but as was suggested, don't get one with moving parts. Link to comment Share on other sites More sharing options...
aero901 Posted February 3 Share Posted February 3 I've been using LED bulbs with cooling fans for a few years now and the fans haven't been the point of failure. The driver circuit or the LED chips themselves seem to let go first. Would recommend the mid-range to higher-end LED bulbs over anything available in the incandescent flavor. They are definitely brighter and will last a little bit longer than the high output filament bulbs but they may also cost a little more... Just bought a set of H7 S-V.4 LED bulbs that I'm getting ready to install. Link to comment Share on other sites More sharing options...
silverton Posted February 3 Share Posted February 3 https://www.headlightrevolution.com/9005-gtr-lighting-csps-mini-PF1.9005_2?quantity=1 I put these in the highbeams of my third gen a couple years ago, I used them as much as I could when it was my daily driver, they're god damn laser beams and I would win every high beam fight. Link to comment Share on other sites More sharing options...
Bobsyouruncl Posted February 5 Share Posted February 5 On 2/3/2024 at 10:57 AM, silverton said: https://www.headlightrevolution.com/9005-gtr-lighting-csps-mini-PF1.9005_2?quantity=1 I put these in the highbeams of my third gen a couple years ago, I used them as much as I could when it was my daily driver, they're god damn laser beams and I would win every high beam fight. You put these in your headlights? Link to comment Share on other sites More sharing options...
silverton Posted February 5 Share Posted February 5 In the highbeams of my third gen. third gen uses the low beam for DRL so they are never on unless I want them to be. It's my girlfriends car now. Link to comment Share on other sites More sharing options...
