Help identifying connector behind clutch pedal + cut wire on steering column
Hey all!
Been doing some electrical work on my car, trying to fix the absolute mess the previous owner did, and I came upon this unplugged harness:
From what I can see in the service manual, this is connector B96 - Daytime Running Light Module.
Just to be 100% correct, can anyone confirm?
There's also this cut wire under the steering column:
I can't seem to find what connector this is on the service manual. Any idea?
Car is a 2005 LGT MT.
I see. I currently have an issue that the left turn signal turns on solid   when I turn the headlights on, and blinks fast while they are on.
If the headlights are off, it works normally. I suspect a grounding issue tbh, but I'm wondering if the DRL could have anything to do.
I had a bunch of exterior lighting issues on my '07 with similar wiring hackery. That small plug under the steering column is for the park light switch. I can't remember what the idea behind that modification is but it actually wasn't the main cause of my lighting issues.
There's a bundle of wires tucked into the left front fender above the wheel well liner. In there is a solder joint that breaks down over time that I had to fix. Unfortunately, I don't remember what color that wire is.
  • Like 1
