Flxr_88 Posted September 17, 2023 Share Posted September 17, 2023 I have a 05 lgt wagon, and have got a bottle of new coolant. Subaru coolant to be exact. I drove the car around and it had a bunch of white smoke one time. That indicated a coolant leak I thought. I heard a sipping or sucking noise from the turbo resivour and replaced the cap, and burped the system. The coolant issue seemed to get better as the car ran slightly cooler and I could no longer smell anything. I left the car to sit for about a week as I got busy with other things, go back to check on the levels, and find it at the low line. I left it at the Full line, or even more by accident. No leaks can be seen underneath the car, and not sure what else to do. Had the head gaskets replaced a while ago, has an aftermarket radiatior, and just had the intercooler taken off anf reinstalled by Six Star motors to replace a vacuum leak. All of the work on this car has been done by Six Star motors, or Firestone up until I started troubleshooting some of this myself, like replacing the cap, and refilling coolant. I also put the Subaru conditioner in there, even though some said it can be argued I do not need it. Link to comment Share on other sites More sharing options...
Flxr_88 Posted September 17, 2023 Author Share Posted September 17, 2023 Compression tests done, came back normal, could this be coolant contracting? Not fully bled and sucking some up and comntracting too? Link to comment Share on other sites More sharing options...
silverton Posted September 17, 2023 Share Posted September 17, 2023 your reservoir should be at the full mark at operating temperature and will be down by the low mark when it cools down. Link to comment Share on other sites More sharing options...
Flxr_88 Posted September 17, 2023 Author Share Posted September 17, 2023 Got it Thanks Link to comment Share on other sites More sharing options...
