08Spec_B Posted September 14, 2023 Share Posted September 14, 2023 (edited) Year, Make and Model: 2008 Subaru Legacy GT Spec.B Color: Quartz Silver Metallic Miles: 190,060 Transmission: 6 Speed Manual Title: Clear - no accidents Lien: No liens Location: Orem, UT VIN: 4S3BL696283208689 Seller's email address: ethannakaya@gmail.com Asking Price: $17,000 Up until about 2 months ago I never thought this day would come, but here we are. My 08 QSM Spec B is for sale with 190k on the chassis. It was down for a year while getting a new motor, original spun a main bearing at 187k. New built longblock was broken in using builders and tuners recommended process, now has 3k miles on it. It is not perfect cosmetically, it does have the normal rock chips and dings that a daily driver accrues. Mod List: Drivetrain: -Oil change @190,050 -New Battery @ 178k -Battery relocation with 1/0 gauge, inline fuse and breaker -Treadstone TR1035 FMIC core -Rev 9 silicone turbo inlet -Custom in-fender intake -IAG V2 TGV deletes -ID1050X injectors with SS internal filters (freshly cleaned and flow tested) -6an parallel PTFE fuel lines -Radium fuel rails and dampers -Aeromotive adjustable FPR -AllTheFuel 10 micron inline fuel filter -Aem 320lph fuel pump -Chase bays thermostatic sandwich plate -Mocal oil cooler -IAG AOS -AEM IAT sensor -HKS SSQV BOV -Grimspeed EBCS -Koyo radiator -Silicone rad hoses -Custom 321SS v-band ELH -Custom 321SS vband 44mm EWG up pipe -Tial MVR 44m EWG -BNR Billet 20G (freshly rebuilt w/ new motor) -SS turbo oil feed line -Megan racing catless DP -HKS silent hi power resonated mid pipe -Prodrive axle backs BP fitment -Accessport v3 353hp/349tq on 91 oct. -Made 407hp/373tq on e85 (tuned by simple performance in SLC) -Fumoto quick drain valve -Secondary air pump delete -Mazda rx8 oil filter -Powdercoated engine accessory brackets -Greddy/Trust oil cap -Greddy clutch cap -Motul Trans fluid Engine Build: -New RA calse halves -Closed deck service by outfront -Manley platinum 99.75 pistons -Rings gapped for up to 32 PSI of boost -Manley Turbo Tuff I beam rods -ARP rod bolts -ACL main and rod bearings -ARP 625+ heads studs -New shimmed 11mm oil pump -Nitrided Crank -New D25 head castings -Oem cams out of good motor -GSC std size intake valves -GSC std size super alloy exhaust valves -GSC viton seals -GSC spring seats -GSC springs and Ti retainers -BC billet keepers -Killer B oil pickup/baffle -New oil pan -New Oil Control Valves's -New oil feed and avcs lines -Polished valve covers -Exedy HD hyper twin disk -Goodridge SS clutch line -ACT monoloc collar -OEM NTN throwout bearing -OEM nachi pilot bearing Suspension and Handling: -Cygnus X-1 series coilovers (hyperco spring upgrade, spring rates 8k F / 7k R) @ 184k -24mm Whiteline front sway bar -21mm JDM wangan gulf rear sway bar -Cobb RSB reinforcement brackets -Group N motor mounts -Polyurethane sway bar bushings -Energy suspension rear diff bushing inserts -Moog upgraded sway bar endlinks (F/R) -Megan racing adjustable rear lateral links -STI option flexible front strut tower brace -STI option flexible front subframe brace -Kein trans mount -Poly pitch stop mount -Perrin brake master cylinder brace -Clutch master cylinder brace -15+ STI steering rack -Enkei Triumph 18x8 et45 -GT Radial Champiro UHP A/S 235/40r18 -Cobb spec b specific short shifter -Whiteline front and rear shifter bushings Interior: -Jdm double din kit w/ mcintosh hvac unit -Kenwood DMX906s headunit -Tightfitfab adapter harness w/ axxess metra swc module wired in -Alpine DDL linear component front speakers -Rockford fosgate punch rear speakers -Soundqubed 4 gauge amp wiring kit -All doors already ran for a 4 channel amp with heavier wiring -JDM double din vent bezel modified for LHD -Liberal center gauge/vent shade -All weather floor mats -Charcoal alcantara EU shift and ebrake boot -EU console w/ red LED lit cupholders -Tuned by sti alcantara armrest/storage cubby -Alcantara "Legacy" stitched passenger knee pad -Custom Forged CF D style w/ red stitch steering wheel -OEM option garbage can -Custom forged CF trims/handles -Custom 2x2 twill CF Ebrake handle -K2 Gear CF airbag emblem -DMND Black SI drive cover -Blitzen black sun visors -Cabin air filter changed @ 187k Exterior: -Wingless trunk -Stanza V1 CF trunk lip (painted) -Aftermarket JDM CF rear window lip -JDM sport option sideskirts -JDM Spec B grille -JDM spec B front bumper -Gialla switchback drls fitted into fog bezels -JDM option blue winkers/grampus signals -JDM power folding mirrors -Prova yellow convex lenses -Legacyoddsnends folding mirror harness -EU switch bank w/traction control button -JDM multicolor fogs -DAMD rep vented fenders -Tinted windows -Rain guards -Rear s209 bumper vents Included for asking price: -Killer b oil pan with npt adapter (brand new) -JDM sport skirts (modified to work with damd fenders) -JDM/EU Leather rear armrest with cupholders (since rear cupholders were removed for oe garbage can placement) -JDM mirror finishers -JDM fitment INGS grille -Cusco rear subframe brace -Hood struts -Corazon rear subframe brace -JDM rear sedan bumper fogs -Extra oem airbag cover -Black rallyarmor mud flaps -Extra Oem throwout and pilot bearings -Custom sequential led tailights (do need to be opened and have a couple sections of solder re-flowed) -Unmodified OEM jdm fog bezels -JDM power steering cover -JDM Gialla strakes (needs cf repair) -cheap JDM bl5 rc car -JDM tbsti black c pillar covers -NA longrunner intake manifold -full (un-cut) 60x5ft roll of midnight red metallic wrap from innozetek Edited September 14, 2023 by 08Spec_B Link to comment Share on other sites More sharing options...
08Spec_B Posted September 14, 2023 Author Share Posted September 14, 2023 1 Link to comment Share on other sites More sharing options...
08Spec_B Posted September 14, 2023 Author Share Posted September 14, 2023 Link to comment Share on other sites More sharing options...
shralp Posted September 15, 2023 Share Posted September 15, 2023 Oh man, sure you want to part with the awesome build? Dang… Link to comment Share on other sites More sharing options...
Akl406 Posted September 27, 2023 Share Posted September 27, 2023 How is the undercarriage for rust so you have any pictures? Looks very clean! Link to comment Share on other sites More sharing options...
boxkita Posted February 17 Share Posted February 17 oh my! sad to see this one up for sale? damd fenders 6mt oh my Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
