Scubaboo Posted July 28, 2023 Share Posted July 28, 2023 Here is a pic of a strut assembly for a 2010 Outback that shows the strut mount installed on it. Does the lower part of the mount, which is also the upper spring perch, compress upwards over time? Link to comment Share on other sites More sharing options...
Scubaboo Posted July 28, 2023 Author Share Posted July 28, 2023 Here is the exact same model of shock mount as in the OP, here installed on a Forester. It's well used and *looks* substaintially lower. It could be the angle though? Link to comment Share on other sites More sharing options...
silverton Posted July 28, 2023 Share Posted July 28, 2023 It's rubber so probably. Link to comment Share on other sites More sharing options...
Scubaboo Posted July 28, 2023 Author Share Posted July 28, 2023 ^That's what I was thinking? I'm not sure if the spring perch is part of the rubber-suspended area or not. Link to comment Share on other sites More sharing options...
DrD123 Posted July 28, 2023 Share Posted July 28, 2023 The spring seat (rubber part that sits inside the "cup" part of the upper mount) will creep a little, but as it creeps the additional "space" is taken up by the spring (the spring is always under compression when the strut is assembled) - if you take apart a rear strut assembly, the rubber seat will have a permanent impression of the spring in it, whereas the new one doesn't (it compresses when the spring is installed, and eventually takes on a permanent set in that position) the upper mount is more or less all metal as far as the vertical part goes (with the exception of the seat - the seat is part 20375 in the diagram) - the distance to measure (to see if there is a change) is the face the spring mounts/presses against and the mounting surface of the strut (where it mounts to the frame) or the point where the strut shaft bottoms out on the mount - the cup part is likely going to be a little different when comparing parts from different manufacturers. Link to comment Share on other sites More sharing options...
Scubaboo Posted July 30, 2023 Author Share Posted July 30, 2023 Well, just confirmed they do. I went out and got a new mount and compared it with the old. 1 Link to comment Share on other sites More sharing options...
DrD123 Posted July 31, 2023 Share Posted July 31, 2023 that's interesting - I didn't realize that the middle part was rubber (I remember drilling out the rear mounts when I installed Koni's, but the only rubber I remembered was the spring seat and I thought maybe a little around the hole the strut goes through. Link to comment Share on other sites More sharing options...
