cbroo Posted December 20, 2005 Share Posted December 20, 2005 I took my car in for a 90k maintence check. The mechanic said my knock sensor is out. Anyone have advice on price, and what it affects. He also told me it's running rough. I know a little bit but not as much as most of you. Any advice or feedback will help. I have a 2001 LGT so it's a little older model. Link to comment Share on other sites More sharing options...
Opie Posted December 20, 2005 Share Posted December 20, 2005 Knock Sensor detects knock (pinging, etc) in the engine and advances or retards timing to correct the knock. If the sensor is bad, the car will usually run very poorly....probably why it runs rough.... It's not hard to replace, but you'll need to clear the ECU memory once it's replaced to clear the code. Link to comment Share on other sites More sharing options...
cbroo Posted December 20, 2005 Author Share Posted December 20, 2005 cool, the guy didnt quote me a price, he said tomorrow he will know, any idea on price and labor. There probably not going to charge too much for labor but for the parts I'm a little scared. I have a catback exhaust and a K&N airfilter with a straight pipe running to my airbox. Will this cause this to happen frequently, or will it be fine after the service is complete? Link to comment Share on other sites More sharing options...
Opie Posted December 20, 2005 Share Posted December 20, 2005 Automatic or Manual? Link to comment Share on other sites More sharing options...
cbroo Posted December 20, 2005 Author Share Posted December 20, 2005 manual. Link to comment Share on other sites More sharing options...
Opie Posted December 20, 2005 Share Posted December 20, 2005 P/N: 22060AA070 sells for about $75-$80 and usually runs about an hour labor (that includes diagnostic, replacing the sensor and resetting the ECU. Link to comment Share on other sites More sharing options...
cbroo Posted December 20, 2005 Author Share Posted December 20, 2005 Thanks opie very helpful. I will use this knowledge tomorrow Link to comment Share on other sites More sharing options...
GTsleeper Posted December 20, 2005 Share Posted December 20, 2005 Opie were u get ur info? I should go there!!!. & yes im beening in ass!! Link to comment Share on other sites More sharing options...
hovied Posted December 20, 2005 Share Posted December 20, 2005 super common problem with that year.... Opie is right about part #.... If ya know someone in parts you could get cost plus 10% which is $62.15..... But you should have it replace as soon as possible.... ______________ tHe HoV Link to comment Share on other sites More sharing options...
mwiener2 Posted December 20, 2005 Share Posted December 20, 2005 moved to older leggy My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
MDW25gt Posted January 9, 2006 Share Posted January 9, 2006 where is the knock sensor located under the hood? Link to comment Share on other sites More sharing options...
stanjk3 Posted January 10, 2006 Share Posted January 10, 2006 Had it replaced on our car in Aug. Ran a lot smoother afterwards. IIRC was ~$150, guess it's tougher to replace on the 2.2L. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
cbroo Posted January 11, 2006 Author Share Posted January 11, 2006 so i got my car back, $900 total. got new knock sensor, gaskets, valve covers and spark plugs. well labor is what killed me Link to comment Share on other sites More sharing options...
