jonnyt88 Posted May 17, 2023 Share Posted May 17, 2023 (edited) Does a legacy and outback run the same engine maps? I'm looking to flash mine with a base map as I suspect it has a M/T map on it. The only option I found on Romraider has both cars together... Where as 05/06 they had separate maps for outback and legacy (though who knows, they could be 100% identical). Here is the link to the base maps available https://www.romraider.com/forum/viewtopic.php?f=35&t=7591 Edited May 17, 2023 by jonnyt88 Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 18, 2023 Share Posted May 18, 2023 Should be. Same HW. 1 Link to comment Share on other sites More sharing options...
m sprank Posted May 19, 2023 Share Posted May 19, 2023 Stock tune was the same between the LGT and OBXT. Link to comment Share on other sites More sharing options...
