nebula72 Posted May 16, 2023 Share Posted May 16, 2023 Members 10 Posted 2 minutes ago Hello all, So after a turbo failure destroyed my sons engine (2009 LGT), we decided to keep the car, pull the engine and try to save money for a new short block as I dont want a take a chance on swapping a used engine. A friend of a coworker has a brand new still in box Subaru STI short block Part # 10103AC030 that he is looking to sell but when I look it up the application is for 2004 -2007. 1. Will this block work with my 2009 parts (heads/intake/etc)? 2 Do I need to make any modifications to make this work (delete air pump)? 3 Are there any other issues that I need to worry about or should I just spend more on the OEM replacement short block? Please pardon my ignorance as I am still learning and don't want to make a big dollar mistake by buying this block. Thanks in advance. Link to comment Share on other sites More sharing options...
tysparks81 Posted May 16, 2023 Share Posted May 16, 2023 That short block should work fine. You will be using the heads/intake/sensors from your existing blown motor. You can reuse your existing air pumps. But it should be pretty straight forward after that. #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
