Dalee1104 Posted April 6, 2023 Share Posted April 6, 2023 Hey all, so I'll preface by saying this isn't technically for a legacy but as I'm sure you guys are all aware the engines are shared amongst subarus. If not okay please remove this topic. Anywhos, the car in question is a 2001 subaru forester. The previous owner mentioned it has an engine swap from a 2003 subaru outback, intake manifold is still from the forester and whatnot. I'm pretty sure the engine is the same? I got this car for free in exchange for some work, the body is clean, interior is clean, but has a blown 5 speed and the engine has a cylinder 4 misfire. Runs okay, has a uneven idle, a little lumpy, but does still run and drive with no flashing of the engine light. The trans I already have squared away, picking one up this Saturday and going to stuff it in but the engine is more worrisome. I went ahead and did spark plugs and plug wires and when I pulled the cylinder 4 spark plug out the plug was huge. Turns out, it's a spark plug repair kit you can buy at autozone. The cylinder head had been stripped, and the repair kit taps new threads in and uses red loctite to secure a new fitting for the spark plug to thread into. I'm trying to get second opinions on what I should do. I was thinking about doing a leakdown/compression test to see if I'm losing pressure through that plug. Do any of you guys have any experience with these spark plug repair kits? Do they actually work? Am I most likely losing compression on that cylinder causing the misfire? Could the misfire be caused by something else like a coilpack (figured if that was bad id see misfires on all cylinders as its one unit, not coil on plug)? I'm leaning towards the only real way to tell is a compression test or leak down and I will likely chase that. I'm predicting I'm going to have to tear the engine down and replace the cylinder head. I was really hoping it would be something smaller but alas that's the way it goes, so I'm trying to be prepared for whatever the situation is. I greatly appreciate any insight yall can provide! Link to comment Share on other sites More sharing options...
m sprank Posted April 7, 2023 Share Posted April 7, 2023 Leak down to confirm. But sounds like you need a new head and a possibly a rebuild at the same time. Link to comment Share on other sites More sharing options...
Dalee1104 Posted April 7, 2023 Author Share Posted April 7, 2023 That's what I feared lol but it's what I was expecting as well. Appreciate it Sprank 1 Link to comment Share on other sites More sharing options...
silverton Posted April 7, 2023 Share Posted April 7, 2023 (edited) the coil packs on those are waste spark so when you have a failure it affects two cylinders, as the paired cylinders fire together. 1 and 2, or 3 and 4 You could be losing compression through a bad thread fix and would cause an occasional misfire, like sprank said... your best bet is finding a good set of heads to put on it. Edited April 7, 2023 by silverton Link to comment Share on other sites More sharing options...
Dalee1104 Posted April 7, 2023 Author Share Posted April 7, 2023 Yeah more and more evidence pointing towards just needing a new head in whole. What a pain I was hoping for an easy fix lol Link to comment Share on other sites More sharing options...
