garygbnj Posted March 30, 2023 Share Posted March 30, 2023 2010 Legacy GT, Ltd. About 390 brake hp. Presently running a Southbend clutch. Intermittent slippage. Only about 40k on the clutch. What performance clutch, with reasonable pedal pressure, is recommended. The car is not driven hard. No "red line" take offs. Thanks Link to comment Share on other sites More sharing options...
m sprank Posted March 30, 2023 Share Posted March 30, 2023 I would recommend Southbend. Link to comment Share on other sites More sharing options...
garygbnj Posted March 30, 2023 Author Share Posted March 30, 2023 Thanks Link to comment Share on other sites More sharing options...
m sprank Posted March 30, 2023 Share Posted March 30, 2023 I realize you already have one and maybe not the answer you wanted to hear. But, I had the best and most consistent results with Southbend. Not sure which stage/model you are running. How did you come up with brake power? Did you have access to friction brake or an absorption dyno? Engine on a stand in a room being measured at the flywheel? Best I can "guess" is minus 20% for loss through the transmission/drive line. So about 310 at the wheels? Link to comment Share on other sites More sharing options...
garygbnj Posted March 30, 2023 Author Share Posted March 30, 2023 The dyno generated whp. I used a calculation to arrive at bhp. Link to comment Share on other sites More sharing options...
m sprank Posted March 30, 2023 Share Posted March 30, 2023 Ok. Are you running a stage 3 daily set up? Could try a stage 3 endurance. Link to comment Share on other sites More sharing options...
garygbnj Posted March 30, 2023 Author Share Posted March 30, 2023 I have about 390 bhp. I have two recommendations to continue using Southbend. My only complaint is lifespan. Link to comment Share on other sites More sharing options...
m sprank Posted March 30, 2023 Share Posted March 30, 2023 Some people like to slip a clutch a little more than others. Some people experience heavier stop and go traffic than others. Some disc materials wear faster. 40k might seem low miles to some and decent to others. I understand. Sometimes its the nature of modding. Link to comment Share on other sites More sharing options...
