Cancer Man Posted March 18, 2023 Share Posted March 18, 2023 Hi, Can someone help me with the name of the part along with the complete SKU. It sits next to the oil pressure switch. Diagram it says 22630, I am stuck. Please help Link to comment Share on other sites More sharing options...
silverton Posted March 18, 2023 Share Posted March 18, 2023 https://parts.subaru.com/a/Subaru_2016_Forester-25L-CVT-Base-Premium/_54102_6030226/TIMING-BELT-COVER/S13-022-01.html 1 Link to comment Share on other sites More sharing options...
Cancer Man Posted March 18, 2023 Author Share Posted March 18, 2023 22 minutes ago, silverton said: https://parts.subaru.com/a/Subaru_2016_Forester-25L-CVT-Base-Premium/_54102_6030226/TIMING-BELT-COVER/S13-022-01.html Bro, I spent three hours to find the exact name and the number. WOW thanks a lot. Link to comment Share on other sites More sharing options...
ammcinnis Posted March 19, 2023 Share Posted March 19, 2023 I think that may not be the correct part identification for a 2016 Legacy 2.5. Edit: Per the H4 (FB25) FSM, the part in question is the oil temperature sensor, not the coolant temperature sensor. It's mounted right next to the oil pressure switch, and both share the same oil gallery just downstream of the oil filter. (N.B. There is no coolant in the timing cover.) That said, I don't know whether or not the same part number is correct for both oil and coolant temp sensors. The temperature ranges are similar, but the chemical and pressure environments are quite different. 2 "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Cancer Man Posted March 19, 2023 Author Share Posted March 19, 2023 6 hours ago, ammcinnis said: I think that may not be the correct part for a 2016 Legacy 2.5. Yeah it is not the correct part. But I like to say, i dint know these is a way to expand the diagram to get the part name and the number. When silverton sent me the link, it made my search easy to find the right part. Unfortunately OEM is currently not avalable at my nearest dealers. Found the same on Rockauto for cheap. Noting wrong with the part now, but both the switch and sensor is very rusty, so replacing it before it get bad. Will order it today. Thank, I appreciate it. 1 Link to comment Share on other sites More sharing options...
