afrascione Posted March 12, 2023 Share Posted March 12, 2023 i need new struts on my 2010 legacy. i live in connecticut and got a quote from Meineke $900+. that is a low quote so far. can anyone get me a better deal. cant replace them myself senior here. Link to comment Share on other sites More sharing options...
DrD123 Posted March 16, 2023 Share Posted March 16, 2023 (edited) If you can find someone local to help you out, you can get Monroe fully assembled spring/strut/bearing assemblies from Rockauto pretty cheap - about $450 shipped for all 4 units, then it's remove the old and install the new (you will need to get an alignment afterwards since the Legacy uses camber bolts on the front. Given the age, you'll almost certainly want to replace the strut tops/bearings. Edited March 16, 2023 by DrD123 Link to comment Share on other sites More sharing options...
m sprank Posted March 16, 2023 Share Posted March 16, 2023 I know of no shop that will install your supplied parts for that type of work. Shops dont make enough on labor alone to keep the doors open. They also do not want to warranty their labor for your parts. If you are not going to allow them to make a profit and sell you the parts that they then warranty you will probably be told to pound sand. You might find a "mobile mechanic" to do the work. I dont know if I would trust some of them, but... it is not a difficult job. There are a ton of "shade tree" mechanics in my area that would take that job. But they might also charge you $75 per corner. Your estimate might include an alignment and you will need to have one done after the work. You can check around for a trusted "side job" mechanic and compare price to a "Menieke". Just dont forget the alignment and any warranty that a shop would provide. I would hate to see someone try to save $100-$200 and end up with a bad strut needing to pay for labor and and alignment again. If you are in the Balt/DC area I can help. Otherwise, good luck! 1 Link to comment Share on other sites More sharing options...
silverton Posted March 16, 2023 Share Posted March 16, 2023 2 hours ago, m sprank said: Just dont forget the alignment and any warranty that a shop would provide. I would hate to see someone try to save $100-$200 and end up with a bad strut needing to pay for labor and and alignment again. penny wise and pound foolish! 1 Link to comment Share on other sites More sharing options...
afrascione Posted March 22, 2023 Author Share Posted March 22, 2023 thank you. i'm working the issue and getting real close. i really think it should a $700 with alignment and struts tops. Link to comment Share on other sites More sharing options...
