FS - Location (CA) 2005 Legacy GT Wagon 5MT Modded
need bb
Year: 2005
Make: Subaru
Model: Legacy GT Limited Wagon
Color: Satin White Pearl; 1 of 109 LGT Ltd’s
Interior: Black leather
Miles: 132,000
Transmission: 5 speed manual
Title: Clean
Lien: None
VIN: 4S3BP676656365501
Asking Price: SOLD
I have decided to sell my beloved LGT wagon after 12 years. I am the 2nd owner having purchased the vehicle from the original owner in totally stock condition in 2011 with 51k miles on the car.  My goal for the car was to add performance, while also maintaining reliability and comfort. Because of this, mods were focused on improving performance while keeping the drivability and reliability as close to stock as possible. I succeeded with this vision and the car has been reliable all the way from 11,000ft elevations in Colorado to 120F heat in Death Valley.  The car is mechanically sound is ready for many more miles ahead.
This is not a show car and the exterior has slight hail damage, some dings on the front bumper and side panels, and a dent in the left rear quarter panel. The interior is in excellent condition and the car has never been smoked in. There was a minor low speed accident which slightly damaged the front bumper. The car has lived in the Midwest, East Coast, and West Coast so there is surface rust on the underbody.
Overall, this is an extremely well put together Legacy GT wagon that is faster than an STI, but still has plenty of room for the family, home improvement projects and outdoor activities.
  • Major maintenance items such as brakes, tires, and battery have all been recently replaced
  • Car is tuned for 91 pump gas and e85
    • Dyno’d 290WHP on a Mustang dyno on low boost early on in the build
    • Virtual dyno shows 300WHP on pump gas and 370WHP on e85 for the current tune
Carfax Report - Carfax for some reason shows a 3rd owner (when I registered it in CA) which is not correct
Additional Photos
Mod List:
Motor:
Motor was built by Area1320 Motorworks, Nazareth, PA in May 2014.  Engine was built to reliably handle 400-500WHP.  I wanted the motor to last so I went with tighter PTW clearances and 4032 based pistons.  Engine runs great with 50k miles on the build. Oil is changed every 4-5K miles with Rotella T6.
Cosworth 99.75mm pistons
Manley H-Tuff rods
Tigwerks oil pickup
ARP head studs
ACL rod and main bearings
Gates timing belt
OEM 10mm water pump
TGV delete
Engine/Transmission:
Kinugawa TD05-20G 8mm Turbo
Grimmspeed TMIC
Grimmspeed Uppipe
Grimmspeed ported manifolds and crossover pipe
Grimmspeed EBCS
DW 850cc injectors
Walbro 255 fuel pump
WRX FPCM with upgraded fuel pump wiring
K&N Typhoon Intake
Perrin turbo inlet
IP&T Filtered Turbo oil supply line kit
Forge BPV
CNT catted downpipe
Subaru SPT v2 catback
STI Group N engine mounts
STI Group N transmission mounts
South Bend Stage 3 daily clutch
TSK3 transmission sleeve kit
Suspension/Brakes:
Centric Premium rotors front and rear
Hawk Performance HPS 5.0 brake pads
Grimmspeed master cylinder brace
Koni Yellow struts
Epic springs
Hotchkis 25mm front and 22mm rear sway bars
Kartboy end links front and rear
AVO rear sway bar mount brace
Whiteline front control arm bushing
Whiteline front caster kit
Energy Suspension swaybar bushings front and rear
Wheels/Tires:
2011 OEM WRX wheels with Hankook Ventus V12 evo2 summer tires
2005 OEM Legacy GT wheels with Bridgestone Blizzak WS80 snow tires
Other:
Parrot MKI-9000 Bluetooth phone/music
Jazzy Engineering Aux In
Innovate LC-1 wideband tied into BtSSM
BtSSM Android boost gauges and monitoring
WeatherTech floor mats
LED interior lights
LED low beam bulbs
Subaru low profile 1.25” hitch (used for a bike rack)
Subaru roof rails
Everstart Maxx battery purchased in 2022
Edited by need bb
  • Like 3
Car is deff worth more than $12k since it has IP&T parts installed.  Might want to mention that car is not register-able in current condition in California and buyer will need to verify emissions laws in their state.  Otherwise, like Booze said, Good Luck!!!
  • need bb changed the title to FS - Location (CA) 2005 Legacy GT Wagon 5MT Modded
