Samets Posted February 24, 2023 Share Posted February 24, 2023 I know I've seen it on these pages somewhere but I can't find it. Car thought I had 30 miles left to empty and she was wrong! I don't like being stranded at 5am n a major interstate... Link to comment Share on other sites More sharing options...
DrD123 Posted February 24, 2023 Share Posted February 24, 2023 It's never going to be perfect, but you can adjust things using the dealer customization mode Link to comment Share on other sites More sharing options...
DrD123 Posted February 24, 2023 Share Posted February 24, 2023 (edited) I would assume that adjusting the average fuel economy correction would do it, but I don't know for sure. (it is never going to measure how much is in the tank beyond what the level switch tells it - once you get about to empty, even the level switch isn't going to be particularly reliable... For my car, I record fill-ups and miles per gallon of the display vs. actual and after 250 or so tanks of gas, I average +4.9% (display reads 4.9% higher than average, with a standard deviation of 2.4, so it generally is off by 3 to 7%, but some of that error is probably due to my calculation being based on how much gas I add when I fill up, which will very from station to station a little, I bet) Edited February 24, 2023 by DrD123 Link to comment Share on other sites More sharing options...
DrD123 Posted February 24, 2023 Share Posted February 24, 2023 also be mindful that miles to empty is based on some sort of average consumption rate, which can vary quite a bit from instantaneous consumption rate if the average is based on a bunch of highway miles, and you are now driving around the city... (I have no idea if it uses an overall average or has a rolling average of a particular time period) Link to comment Share on other sites More sharing options...
silverton Posted February 25, 2023 Share Posted February 25, 2023 30 miles remaining is basically a gallon left and absolutely no way for DTE to be accurate. I'm sure the low fuel level light was on and had been on, this was definitely driver error putting too much trust in a convenience feature. Sorry you got left stranded but this isn't the cars fault. That being said, my DTE seems to go off the last tank. If it was all freeway driving my DTE is over 300. if I did my usual 4 mile round trip work commute the whole tank, it'll show less than 200. My average MPG displayed has been exactly +1 of actual each tank I've put in my car. Link to comment Share on other sites More sharing options...
