Buspilot23 Posted February 16, 2023 Share Posted February 16, 2023 Hello, randomly my car's built in microphone (stock head unit) stopped working. This affects my BT phone calls including when using AppleCar Play. Has anyone encountered this issue? If so, should I replace the factory microphone or bypass with an external aftermarket microphone? Link to comment Share on other sites More sharing options...
Antimatter85 Posted February 24, 2023 Share Posted February 24, 2023 Try replacing the DCM fuse (#9 in the box under the hood). People often pull it out to eliminate the starlink system battery drain - not realizing it impacts some other functions. Link to comment Share on other sites More sharing options...
Buspilot23 Posted February 24, 2023 Author Share Posted February 24, 2023 Thank you so much for responding! I will check this solution this evening. Thanks again. Link to comment Share on other sites More sharing options...
