ohno06gt Posted February 4, 2023 Share Posted February 4, 2023 Tried to start my car this morning, it cranked a few times then I heard a whining sound for a split second. Now it's cranking really slow and won't start. Battery voltage is good and not throwing any CEL's. It was -20 degrees outside this morning. Any ideas? Possibly starter? My neighbor said it probably jumped timing but I don't see how that could happen just starting it. Any input will be appreciated. Link to comment Share on other sites More sharing options...
seanyb505 Posted February 6, 2023 Share Posted February 6, 2023 Age of starter? Whining sounds like it wasn't engaging, and the slowness could be cause it's just that sticky in -20. Link to comment Share on other sites More sharing options...
ohno06gt Posted February 6, 2023 Author Share Posted February 6, 2023 Starter is most likely original from what I can tell. Yesterday it was in the mid 40's so I tried to jumpstart it and got the same results. Tried to do a voltage drop test on the starter but not sure if I did it correctly. I had a probe on the wire going to solenoid and the other probe grounded. When first cranking it read around 8v but dropped to 6.5v as cranking slowed down. Link to comment Share on other sites More sharing options...
silverton Posted February 6, 2023 Share Posted February 6, 2023 8v while cranking isn't good, you likely need a battery and an alternator Link to comment Share on other sites More sharing options...
Pleides Posted February 6, 2023 Share Posted February 6, 2023 My starter isn't original and my car hasn't even seen weather as cold as yours. Definitely not a bad idea to replace the battery and see if that starter comes to life after 5 seconds of cranking or so. If not then don't drain the new battery and go out and get a new starter. Might also be worth giving the starter a tap. Link to comment Share on other sites More sharing options...
