MDSubie4 Posted December 26, 2022 Share Posted December 26, 2022 Anyone go to larger amp alternator for sound system? What did you go with and amperage? Did you have any issues? I've heard something in the Outback forum that our alternators are computer driven and the extra amperage may not be accepted or utilized due to some sensor going to the negative battery post...idk, I'm not an eletronics expert suffice it to say. Link to comment Share on other sites More sharing options...
MDSubie4 Posted December 28, 2022 Author Share Posted December 28, 2022 Wow, no one has gone with a bigger amperage alternator for sound system? Are these cars limited by PCM? Link to comment Share on other sites More sharing options...
Infosecdad Posted December 28, 2022 Share Posted December 28, 2022 There have been several, it's just the holidays and traffic to the forums is way down right now. I've never had enough stereo to need a higher amp, but it looks like there are options that would work. Here is a two pager that confirmed a 140 and 160amp alternator that would work. 180amp alternator for our Legacy https://www.dcpowerinc.com/products/13829-180-hp-subaru-legacy-2000-2-5l-h4?rq=yr_2005~mk_subaru~md_legacy~le_2-5l There are a number of other options, people will chime in as they return from holidays. Link to comment Share on other sites More sharing options...
m sprank Posted December 28, 2022 Share Posted December 28, 2022 What do you want to know? Yes, the cars can utilize an HOA. The regulating is done within the alternator. You bypass all OEM when you run your 0g wire from the alt to the battery. Maniac motors is no longer producing HOA to iirc. So, the big boys are all that's left. Not cheap, but the only way to provide juice for bass. I also recommend dual batteries. 1 Link to comment Share on other sites More sharing options...
m sprank Posted December 30, 2022 Share Posted December 30, 2022 Dual battery and under hood wiring from my Forester. Using a HOA in this set up as well. I have installed multiple high output systems in Subies using high output alternators. 1 Link to comment Share on other sites More sharing options...
m sprank Posted January 3, 2023 Share Posted January 3, 2023 Sorry, not the best. But, two pix of a HOA install in a 4th gen LGT. 1 Link to comment Share on other sites More sharing options...
