Mundar Posted November 13, 2022 Share Posted November 13, 2022 (edited)  Year, Make and Model: 2008 Subaru Legacy GT Spec.B Color: Diamond Gray Metallic Miles: ~114,000 Transmission: 6-speed manual Title: Clean Lien: None Location: Sherman Oaks, CA VIN: 4S3BL696383208121 Seller's email address: mundarrr@gmail.com Asking Price: $14,700  Today is finally the day that I decide to list my beloved Subaru Legacy GT Spec.B for sale. I have loved owning and driving this car since I bought it in September 2016 with 89,000 miles on it. I have taken very good care of the car over the years as it was my daily driver. The engine runs great and the transmission shifts are smooth. There are no oil leaks from either the engine or transmission. I’ve kept service records since I have owned it, but sadly, no service records came with the car when I purchased it. This is a California car so there are no signs of rust anywhere. The timing belt was replaced at 102,200 miles with the Aisin timing belt kit with a water pump and an OEM thermostat. The clutch was replaced with an STi OEM style Exedy clutch kit and an OEM Subaru STi flywheel + bolts and rear main seal at 109,000 miles. Oil changes were done with Mobile 1 5w-30 or Rotella every 3,000-5,000 miles. I have the original documentation and the window sticker. As you may know, these cars are quite rare with less than 700 produced for the 2008 model year (https://www.legacygt.com/topic/120075-2007-2009-specb-production-numbers/). The Spec.B has an STi derived 6-speed manual transmission (gears 5-6 are taller) and a Torsen R180 rear differential. The seats are leather with Alcantara inserts, aluminum control arms, and a navigation system. Current modifications installed on the car: Whiteline front (22mm) and rear (20mm) sway bars Kartboy front and rear endlinks EBC front rotors with EBC Red Stuff pads Stoptech stainless steel braided front brake lines + Motul brake fluid Kartboy pitch stop mount Whiteline front and rear shifter bushings + positive shift kit Whiteline rear differential bushing inserts Whiteline front control arm bushings Exedy Sti OEM clutch + OEM Subaru Sti flywheel (installed on 4/18/20) Motul transmission and rear diff fluid Invidia catted downpipe Custom midpipe with a Vibrandt ultra quiet resonator Custom axle back section with GMS mufflers Mishimoto X-Line aluminum radiator (MMRAD-STI-08X) Mishimoto throttle body hose Aisin timing belt kit (installed 8/18/18) which included the water pump K&N panel filter NGK spark plugs (OEM) Work Emotion XD9 wheels 18x8 +45 with new OEM tire pressure sensors calibrated so you don’t have a tire pressure light on the dash. Bridgestone Potenza RE760 Sport 215/45/18 Rally Armor mud flaps Tein Flex Z coilovers Cobb AccessPort V2 is included Lifetime subscription of Sirius radio (this was hardwired in by original owner)  Parts that will be included with the car but not installed: OEM downpipe and full exhaust with mufflers (so you can pass CA Smog) OEM suspension (Bilstein struts with Swift lowering springs) and OEM springs OEM swaybars Other miscellaneous bits like oil filters, gaskets, bolts, etc. A custom axle back section to remove the mufflers to make it louder. This muffler delete sounds really good and brings out the iconic Subaru rumble. I have the OEM wheels as well if you’re interested. They have tires, but they are too wide for the wheels. Two wheels have Hankook Ventus V12 Evo 2 245/35/18 (less than 2,000 miles). Two wheels have Hankook Ventus V12 Evo 245/35/18 (unknown miles).  The car is mechanically sound and drives very well with no issues. However, there are some cosmetic issues with the paint. There are a few scratches and small dings/dents around the car. The hood has some scratches from when a previous owner tried to remove the hood scoop. The fenders and front bumper have some signs of paint fading. The hood was replaced with a hood from another Spec.B from a member on here. Car was involved in a fender bender in 2009, airbags did not deploy. Please feel free to reach out via email or DM if you have any questions.  Edited December 19, 2022 by Mundar Sold 1 Link to comment Share on other sites More sharing options...
BoozeRS05 Posted November 14, 2022 Share Posted November 14, 2022 That thing is ready for another 100k miles, very nicely kept! 1 EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Hoojammyflip Posted November 17, 2022 Share Posted November 17, 2022 Beautiful 1 Link to comment Share on other sites More sharing options...
Mundar Posted December 16, 2022 Author Share Posted December 16, 2022 Sale is pending. Link to comment Share on other sites More sharing options...
fishbird Posted December 18, 2022 Share Posted December 18, 2022 Keep us posted...some of us keep lurking. Link to comment Share on other sites More sharing options...
Mundar Posted December 19, 2022 Author Share Posted December 19, 2022 Sold. Link to comment Share on other sites More sharing options...
