FS - Location: (CA) - 2008 Legacy GT Spec.B SOLD
Mundar
Year, Make and Model: 2008 Subaru Legacy GT Spec.B
Color: Diamond Gray Metallic
Miles: ~114,000
Transmission: 6-speed manual
Title: Clean
Lien: None
VIN: 4S3BL696383208121
Seller's email address: mundarrr@gmail.com
Asking Price: $14,700
Today is finally the day that I decide to list my beloved Subaru Legacy GT Spec.B for sale. I have loved owning and driving this car since I bought it in September 2016 with 89,000 miles on it. I have taken very good care of the car over the years as it was my daily driver. The engine runs great and the transmission shifts are smooth. There are no oil leaks from either the engine or transmission. I’ve kept service records since I have owned it, but sadly, no service records came with the car when I purchased it. This is a California car so there are no signs of rust anywhere.
The timing belt was replaced at 102,200 miles with the Aisin timing belt kit with a water pump and an OEM thermostat. The clutch was replaced with an STi OEM style Exedy clutch kit and an OEM Subaru STi flywheel + bolts and rear main seal at 109,000 miles. Oil changes were done with Mobile 1 5w-30 or Rotella every 3,000-5,000 miles. I have the original documentation and the window sticker.
As you may know, these cars are quite rare with less than 700 produced for the 2008 model year (https://www.legacygt.com/topic/120075-2007-2009-specb-production-numbers/). The Spec.B has an STi derived 6-speed manual transmission (gears 5-6 are taller) and a Torsen R180 rear differential. The seats are leather with Alcantara inserts, aluminum control arms, and a navigation system.
Current modifications installed on the car:
Whiteline front (22mm) and rear (20mm) sway bars
Kartboy front and rear endlinks
EBC front rotors with EBC Red Stuff pads
Stoptech stainless steel braided front brake lines + Motul brake fluid
Kartboy pitch stop mount
Whiteline front and rear shifter bushings + positive shift kit
Whiteline rear differential bushing inserts
Whiteline front control arm bushings
Exedy Sti OEM clutch + OEM Subaru Sti flywheel (installed on 4/18/20)
Motul transmission and rear diff fluid
Invidia catted downpipe
Custom midpipe with a Vibrandt ultra quiet resonator
Custom axle back section with GMS mufflers
Mishimoto X-Line aluminum radiator (MMRAD-STI-08X)
Mishimoto throttle body hose
Aisin timing belt kit (installed 8/18/18) which included the water pump
K&N panel filter
NGK spark plugs (OEM)
Work Emotion XD9 wheels 18x8 +45 with new OEM tire pressure sensors calibrated so you don’t have a tire pressure light on the dash.
Bridgestone Potenza RE760 Sport 215/45/18
Rally Armor mud flaps
Tein Flex Z coilovers
Cobb AccessPort V2 is included
Lifetime subscription of Sirius radio (this was hardwired in by original owner)
Parts that will be included with the car but not installed:
OEM downpipe and full exhaust with mufflers (so you can pass CA Smog)
OEM suspension (Bilstein struts with Swift lowering springs) and OEM springs
OEM swaybars
Other miscellaneous bits like oil filters, gaskets, bolts, etc.
A custom axle back section to remove the mufflers to make it louder. This muffler delete sounds really good and brings out the iconic Subaru rumble.
I have the OEM wheels as well if you’re interested. They have tires, but they are too wide for the wheels. Two wheels have Hankook Ventus V12 Evo 2 245/35/18 (less than 2,000 miles). Two wheels have Hankook Ventus V12 Evo 245/35/18 (unknown miles).
The car is mechanically sound and drives very well with no issues. However, there are some cosmetic issues with the paint. There are a few scratches and small dings/dents around the car. The hood has some scratches from when a previous owner tried to remove the hood scoop. The fenders and front bumper have some signs of paint fading. The hood was replaced with a hood from another Spec.B from a member on here. Car was involved in a fender bender in 2009, airbags did not deploy.
Please feel free to reach out via email or DM if you have any questions.
Edited by Mundar
Sold
  • Like 1
  • 3 weeks later...
  • Mundar changed the title to FS - Location: (CA) - 2008 Legacy GT Spec.B SOLD
