VespaGTS Posted October 19, 2022 Share Posted October 19, 2022 I don’t like how the front bumper cover kept popping loose near the turn signal lamp. So I purchased new mounting hardware but it just doesn’t stay connected. I am hoping someone has solved this small but pain in my ass cosmetic issue. Image attached. 1 Link to comment Share on other sites More sharing options...
k00laid83 Posted October 20, 2022 Share Posted October 20, 2022 I'm having the same issues. I think it's that one clip that's part of the fender. Well I assumed that was the issue. Link to comment Share on other sites More sharing options...
NORULZleggy Posted October 20, 2022 Share Posted October 20, 2022 Ugggh I have the same problem on my driver side just a little. I have to push on it a little with my knee to put it in place. 1 Link to comment Share on other sites More sharing options...
GearJamr Posted October 20, 2022 Share Posted October 20, 2022 Mine used to do that too. My fix? New bumper cover. However, I say that knowing the large oval shaped hole was warped. Popping it out and giving it some heat and putting it back should help it. I also had the bumper cover replaced because mine had a crack in it from PO that was repaired badly. And it was in the body shop for a bunch of other things anyway. Link to comment Share on other sites More sharing options...
VespaGTS Posted October 20, 2022 Author Share Posted October 20, 2022 I will try the heat it method first. The idea of buying a whole new bumper cover and having it painted to match is an expense I’m not willing to accept. I already painted the entire car once. I should’ve replaced the bumper cover at that point, but I didn’t realize it was going to do this. I will give it a shot and report back here how it goes. Link to comment Share on other sites More sharing options...
