Beamercub Posted September 30, 2022 Share Posted September 30, 2022 I'm attempting to replace the roll connector behind the steering wheel. Besides youtube videos i'm having a hard time finding the actual procedure.... Fingers crossed that someone can help in anyway.... I miss my horn! I already have the part, i just really want this to do as smoothly as possible... Link to comment Share on other sites More sharing options...
Beamercub Posted September 30, 2022 Author Share Posted September 30, 2022 I'm trying to find the instructions on removing the steering wheel / screw/ tab locations... Any detailed info on how to remove certain tabs... Where would one find the technical remove and replace instructions? Link to comment Share on other sites More sharing options...
XT-sub Posted September 30, 2022 Share Posted September 30, 2022 15 hours ago, Beamercub said: I'm trying to find the instructions on removing the steering wheel / screw/ tab locations... On subaruoutback.org forums in the ‘Problems & DIY Maintenance > Do-It-Yourself Illustrated Guides’ sub-forum, Brucey did a roll connector (clock spring) replacement under the topic ‘No horn. Clock Spring and 83196AJ04A / 83196AL00A Steering Roll Connector replacement. Subaru Outback’ topic here: https://www.subaruoutback.org/threads/no-horn-clock-spring-and-83196aj04a-83196al00a-steering-roll-connector-replacement-subaru-outback.536739/ While Brucey’s Outback is a 2017 model, the info he posted would probably suit your Legacy. Link to comment Share on other sites More sharing options...
XT-sub Posted October 1, 2022 Share Posted October 1, 2022 For 2015 gen6 Legacy. 2 Airbag Connector.pdf 3 Steering Wheel.pdf 4 Drivers Airbag Module.pdf 14 Roll Connector.pdf 1 Link to comment Share on other sites More sharing options...
Beamercub Posted October 2, 2022 Author Share Posted October 2, 2022 Mission completed. I contacted SOA and was able to get a goodwill credit for service and or parts, amount $350 !! I used that for the $145 roll connector and replaced it myself ! The job was easier than it appeared. Thank you for the help, I appreciate it. Link to comment Share on other sites More sharing options...
